what would be best? - Car Audio Classifieds!
Old 12-21-2012, 10:56 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default what would be best?
been putting off my box design for some time now, i did have one designed awhile back but really dont want to spend almost $200 on aero ports.
With a box this big i only want to have to build it once so i need it close to perfect, i got one week off from work and then i go back to 50+ hours a week on the 3rd.
The box is gonna be for daily, and its going to be for 4 15" RE SE's with FI baskets and soft parts. As of right now iw ant to shoot for [email protected] with about 14sqin of port per cube. Is this gonna be enough port? Also i remember someone saying awhile back that if you have 2 drivers that require 4cuft each in a common chamber box, then you only build the box 6cuft, is this correct?
Gonna be running them on roughly 2200 watts, but plan to move up to a VFL200.1 in the future.
Old 12-21-2012, 11:10 AM
tacomaguy1's Avatar
0/11 sssss4401
I've heard that about the common chamber boxes needing to be smaller, but idk
If one subs needs 2 and I have 2 subs, I always did 4cu.ft. net for both
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 12-21-2012, 09:56 PM
Ryan1126's Avatar
0/11 sssss9178
me too because the other theory doesnt make sense, at what point do you stop cutting airspace in half? what if you have like 12 drivers?
Old 12-21-2012, 10:18 PM
GiGLZ's Avatar
0/11 ssssss514
to cut airspace in half, run double the subs clamshelled/isobaric wired push-pull... you would also double your power as well...
Old 12-21-2012, 10:25 PM
Ryan1126's Avatar
0/11 sssss9178
i dont need to cut my airspace in half i have plenty of room to worjk with
Old 12-21-2012, 10:30 PM
andale927's Avatar
0/11 ssssss754
Feedback Score: 41 reviews
Replace the aeroport with PVC? As long as your port velocity is below 16m/s you won't notice any port noise.
*Incomplete*
08 Nissan Sentra Spec V - 100 shot of nitrous
4 10" AQ HDC3s D1
2x Crescendo BC3500s @ 2 Ohms
270A DC Power Alt
XS Power D3400
As many Duracell AGM G31 Batteries that fit.
Polk DB5251 Component Set
100W x2 Pioneer Amp
Pioneer AVH-P2400BT Head Unit
Old 12-21-2012, 10:31 PM
Ryan1126's Avatar
0/11 sssss9178
i dont want to do that slot port will look much cleaner.
