15" L7 box help - Car Audio Classifieds!
Old 12-21-2012, 11:34 AM
Prohibited Sellers/Buyers
0/11 sssss1285
Default 15" L7 box help
I have a buddy that would like me to help him build a box for a pair of L7's. This will be going in the back of a blazer (pretty sure its a 99). My questions are what volume has worked well for these? would three 4" ports be enough port? And what was the best setup for subs and port?
Old 12-21-2012, 04:10 PM
0/11 sssss1285
Anyone?
Old 12-21-2012, 04:21 PM
Mr.G6's Avatar
0/11 sssss4614
ok wayy back in the day
well about 4years ago.. (before i got into custom subs n such)
i had a 96 jeep cherokee..
i had 2 kicker L7 15s in 9.4 cubes NET volume (after all displacemnts) running on a audiopipe 3k.. had the box tuned to 33hz and used 14" per cube..
for the cheap chinese crap subs they are.. they did get pretty damn loud really..and played down to around 20hz also
bascially kicker subs like what the manual says..
but thats just my experience
2000 Gmc Sonoma ext cab
Old 12-21-2012, 04:22 PM
Mr.G6's Avatar
0/11 sssss4614
so lets say 4 to 5 cubes per woofer
3x 4" port wouldnt be nearly enough
you need like 2 or 3 6" ers
Old 12-21-2012, 04:26 PM
0/11 sssss1285
Damn that's a big box! I was thinking closer to 7.5 cubes! But that's why i asked...
Old 12-21-2012, 04:27 PM
0/11 sssss1285
That's what i was thinking. I had the so i figured i would ask!
Old 12-21-2012, 04:29 PM
Mr.G6's Avatar
0/11 sssss4614
minimum is 3 cubes
max is 6 cubes
Old 12-21-2012, 09:11 PM
0/11 ssssss202
Heres a box design I got from Brett at Kicker. It was to go in a expedition. So like Mr. G6 was saying, you need at least 4-5 cubes per woofer. Just to give you an idea tho....
FREE BOX! 18" Box, dual 6" aero port snb778 Wiring, Electrical & Other Installation Equipment 17 11-09-2010 07:12 PM
Single 12" sub in good box vs. 2 12" subs in box that's a little too small? MisterTedster General Car Audio Discussion & Questions 6 01-07-2010 01:01 AM
