4th order design for a cvr 18 - Car Audio Classifieds!
Old 12-21-2012, 03:15 PM
Beatdown337's Avatar
0/11 sssss1535
Default 4th order design for a cvr 18
Wassup fellas, done plenty or normal ported alignments before but im trying a 4th for the first time. The woofer is an old school cvr 18 and we only have room for a 2:1 ratio. right now im looking at 6.2 cu ft tuned to 45 hz. And the 3.2 cu ft for the sealed section. Does this sound about right to you guys? ill double check with win isd when i get home but im at work right now
Old 12-21-2012, 05:15 PM
0/11 sssss1535
and i also forgot to mention that im doing 12 in per cu ft on the port and the woofer will be on just about 1k
Old 12-21-2012, 05:49 PM
0/11 ssssss425
For your port, do half cone area about.
Old 12-21-2012, 06:09 PM
0/11 sssss1535
so youre saying about 9 sq in?
Old 12-21-2012, 06:16 PM
0/11 ssssss296
area of the 18" sub divided in half. so 127 square inches for the port.
Old 12-21-2012, 06:38 PM
HACKMUNCH's Avatar
0/11 sssss3892
I would go 3 cft max for the 18" on sealed side and rest ported to 47hz
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 12-22-2012, 02:12 PM
0/11 sssss1535
Well i did 6.0 cu ft on the ported side because that was the max according to spec and then just tried to get 3.0 for the sealed side to make my ratio work out. Im just curious to know if u guys think this work well, sound pretty good and of course not destroy the woofer lol
Old 12-22-2012, 02:49 PM
HACKMUNCH's Avatar
0/11 sssss3892
It will work well because a lot of the old school drivers were high qts design. I wouldn't tune much lower than 48hz
TEAM TSA 2013
FACTORY BACKED
Need 4th order design.... joebobclark Enclosure Discussion & Design Construction Help 0 10-27-2012 10:44 PM
Which 4th order design? SPLEclipse Enclosure Discussion & Design Construction Help 6 05-24-2011 09:19 PM
4th order design bassbear007 General Car Audio Discussion & Questions 1 02-17-2011 07:57 PM
how to design 4th order xcaliber Enclosure Discussion & Design Construction Help 11 12-11-2010 05:48 PM
CVR 12's in a 4th order? Back Yard Custom's Enclosure Discussion & Design Construction Help 0 11-28-2010 04:39 PM
