Is there a restriction or difference in setting a slot port like this? - Car Audio Classifieds!
Old 12-21-2012, 07:14 PM
Eth anol's Avatar
0/11 sssssss60
Default Is there a restriction or difference in setting a slot port like this?
Like this? I heard it doesent but i want to try this to create a better loading surface for the sub
Old 12-21-2012, 07:33 PM
98GMC's Avatar
0/11 sssss1265
Nope, I use this style alot where the port get's to be to long to achieve the tuning I want.
The Following User Says Thank You to 98GMC For This Useful Post:
Eth anol (12-21-2012)
Old 12-21-2012, 07:39 PM
Eth anol's Avatar
0/11 sssssss60
Cool, thanks
Old 12-21-2012, 10:16 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Sometimes even more port pieces depending upon length. My dual 8 box has like 4.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-21-2012, 11:36 PM
Eth anol's Avatar
0/11 sssssss60
You think 45s would do me good?
Old 12-22-2012, 01:36 PM
surreal's Avatar
0/11 sssss2489
Depends, if otherwise you would need to put the sub right by the port then yes thats a good idea. If not, then its usually a good idea to try and stay away from too many full bends.
aero-port vs. slot port? thumper21 General Car Audio Discussion & Questions 23 03-22-2011 11:12 AM
