dd fans/box builders help!! - Car Audio Classifieds!
Old 07-23-2009, 12:41 PM
brtnboarder3241's Avatar
0/11 sssss1595
Default dd fans/box builders help!!
Well getting to the point where ill be cutting the holes for the subs.. Now I have older model 9512D's would the cutout be the same as model B listed in this link (note picture of model is at the upper right) http://www.ddaudio.com/dd/caraudio/e...untingData.asp
Im just curious if there is a difference between that info and my older D subs and the cutout size..Thanks
edit: old subwoofer link on right does not have that model
RON PAUL 2012
Old 07-23-2009, 12:43 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
If your basket is the same as the current model basket I would say it is the same, it your basket is different you need to find the cutout for your specific basket.
I'm sure if you call DD they could help you.
/ CAAA Member #2 /
Old 07-23-2009, 12:47 PM
sholiz's Avatar
0/11 ssssss463
wrap a string around the basket inside and do the math
150's in a wall ... cool.
150's under window line, neat.
150's outta the trunk, priceless!
Old 07-23-2009, 12:48 PM
0/11 sssss1595
didnt think about this..haha thank you
RON PAUL 2012
Old 07-23-2009, 01:15 PM
Dyn0miteMat's Avatar
0/11 ssssss337
We just use a big drywall square, a little hand square, and a straight edge
Pretty much just make a HUGE pair of calipers
Resedent box builders? JLAudioCavalier General Car Audio Discussion & Questions 2 05-31-2009 04:11 AM
SPY and other builders, come in! RollerDJ Enclosure Discussion & Design Construction Help 6 03-09-2009 12:22 PM
box builders in wisconsin slammed636 Box Requests 10 09-30-2008 05:30 PM
For all you sub builders out there.... forceww General Car Audio Discussion & Questions 12 08-17-2008 05:45 PM
Attention Box Builders! Patrick Simmons Wiring, Electrical & Other Installation Equipment 0 07-17-2008 03:51 PM
