Need help with my box! (2 12s) - Car Audio Classifieds!
Old 01-01-2013, 04:50 PM
0/11 sssssss21
Default Need help with my box! (2 12s)
I just got two dc audio 12" xl m2s. I have a ford taurus and want build my box outside and slide it in the trunk. So far i've gotten my box to around 3.3 cuft. BTW im sealing the trunk off.
My problem is this: to save room from making the box so big i wanted to do an external aero port. The biggest i can go is 6" though and look how close it is to the subs.
Precision Port 6" Flared Port Tube Kit 268-354
That's the port and middle circle is the not the cutout but the inside flare diameter the cutout is just a little smaller. Also the inside line in the sub circles is the cutout the outside is the actual outside diameter of the subs.
Do you guys think the port is too close to the subs and is only one 6" external aero 17" long for around 34ish hz good enough for 2 12s?
Box for 2 sa-12s help rab6969 (Sundown Audio) 2 09-18-2012 12:09 PM
Box help for two sa 12s Craig28 General Car Audio Discussion & Questions 0 07-13-2011 06:41 PM
FS: 8.5^3 box for 4 12s jbizzle Wiring, Electrical & Other Installation Equipment 21 05-12-2011 04:12 PM
wts bassworkx box for two 12s portered box Zooook Speaker Accessories & Parts 0 02-03-2010 03:16 AM
Box for 4 12s Biggy Build Logs 6 07-09-2009 04:30 PM
