question about the port of my box design - Car Audio Classifieds!
Old 01-03-2013, 01:59 PM
0/11 ssssss143
Default question about the port of my box design
i have designd a box and this is the way the port came out becase i made the depth too long. can i just build it this way because ive never seen any space behind the port before , like mine is.
it was for two skar audio ivx 10s
30 width 12 height. depth 20. port wide 4" port height 12" port length 29" final box volume 2.6 tuned 35hz
Old 01-03-2013, 02:17 PM
ControlFreak's Avatar
0/11 ssssss457
I would guess that you should just extend your port length to the back of the box and eliminate the space behind the port. It will end up being dead space if you keep it as is. However, I'm not a box builder.
Old 01-03-2013, 02:43 PM
0/11 ssssss143
but if i change anything it changes to what the box is tuned too. i might just have to start over
Old 01-03-2013, 03:10 PM
0/11 ssssss577
no.. as long as the total amount of port area is the same nothing changes.. and building that current design would be a waste of time imo.
its as simple as adding say 5" to the first section of the port and subtracting -5" from after the bend.
Old 01-03-2013, 04:03 PM
0/11 ssssss143
ok that makes sence i will do that.
Sub box design air port velocity nwdsk8er Enclosure Discussion & Design Construction Help 4 12-14-2011 02:21 PM
Need Free Box Design For 2 15's/Subs Up/Port Back/28hz Kidthump Enclosure Discussion & Design Construction Help 4 10-08-2011 08:06 PM
need help on port for box design for sa-10s. akmarcos12gauge (Sundown Audio) 2 08-06-2010 12:58 PM
box question (NOT A DESIGN QUESTION) highpsicobra General Car Audio Discussion & Questions 0 07-15-2010 02:10 AM
box design port ? 98Expo Enclosure Discussion & Design Construction Help 4 06-17-2010 05:45 PM
