2 hdc3 15" box tuning questions? - Car Audio Classifieds!
Old 01-03-2013, 09:59 PM
0/11 sssssss22
Default 2 hdc3 15" box tuning questions?
So I have a 1993 Chevy extended cab and am planning on running 2 hdc3 15" subs off a soundstream rubicon 2500 in the rear with the rear seat removed.
I looked on the audioque.com site for the recommended box specs and found the chart with cube specs(9 cu ft) and port specs(144 sq in X 18" long=1.5 cu ft). What I didnt find was what that spec box is tuned to. I would like to know what that comes out to. Hz?
I would like to go with 34 or 35 Hz. So if somebody could tweak this port to get that tune for me that would be awesome
This will be a daily system so im not worried about overall numbers, just want low and clean.
Will be ported up on the drivers side or each end. Would I run into problems porting at each end? Never tried it before but it might look nicer balanced out that way.
I will figure out the measurements in a little bit and post them up for more info to work off of. Thanks
Old 01-04-2013, 01:17 AM
0/11 sssssss22
I would also like to know 9 cubes is before or after port and woofer displacement
Old 01-04-2013, 03:48 AM
spl_robb's Avatar
0/11 ssssss571
if those 9cuft are net. then its tuned to around 39hz
the best box i had for clean and low whas on one 15 @ 27hz 4cuft.
currently running one 18" sub on 5.5cuft box @ 31hz its louder yes but does not kill the lows as the 27hz one.
for your box to be @ 34-35hz 9cuft. net the port needs to be 27" long give or take
(2)10" Mids (2) HornsD290Py S (2)TW 700Ti all PRV
2 x 18" DSS SAVAGES/2 x SOUNDIGITAL 12K @1 ohm
4 BANKS OF SCAPS/ shca ofc cable wire 4 runs.
Old 01-04-2013, 11:58 AM
0/11 sssssss22
Thanks for the info. Definitely taken into considerationAfter looking at a couple online box calculators I have found that by using a port size of 22" high and 6- 1/2" (143 sq in) on a 9 cu ft box the port should be 21.83" long for 35Hz. Does this sound about right?
Old 01-05-2013, 03:10 AM
0/11 sssss5305
Yes that length should be right around 35Hz tuning...
Old 01-05-2013, 03:46 AM
0/11 sssssss22
Awesome. I wanted to make sure I did it right and used a reliable box calculator. Thanks for backing up my research. Glad I asked
Mt 15" sub box tuning spl_robb Enclosure Discussion & Design Construction Help 1 04-26-2012 07:54 PM
2-15" HDC3,what's a good tuning for 'em? jessdabest77 General Car Audio Discussion & Questions 4 11-07-2011 12:41 PM
hdc3 18 box tuning hdman87 General Car Audio Discussion & Questions 18 12-20-2010 02:08 AM
tuning freqs. with HDC3 18" AQ4Lyfe General Car Audio Discussion & Questions 7 10-31-2010 04:50 PM
Questions about box/port size/hz tuning KRestevan Enclosure Discussion & Design Construction Help 1 03-25-2010 06:27 AM
