nissan 240sx hatch box - Car Audio Classifieds!
Old 01-05-2013, 12:01 PM
0/11 ssssssss9
Default nissan 240sx hatch box
Well im looking to go broke this winter and i need help doing so. every setup i put in doesnt hit my standards. Im looking to put a single PSI p2 12 on a hifonics 1700. Now the tough part. I have a max of 15" height, 21" width and a depth of up to 30". I used the re calculator and came up with 15h x 21w x 24d tuned at 32hz 2.5cuft after sub disp(.16cuft). Now which direction should i have the sub and port facing? As you can tell i dont know alot about box building and thats why i need your help. Looking to be loud and hit the lows. Any help would be great. Thanks a friendly noob.
Old 01-05-2013, 12:06 PM
0/11 ssssssss9
BTW I havent ordered the sub/amp yet so if you think i should go with a different setup just say so. And my loudest setup to date was 2 groundpounder 12s on a massive 1000.
Old 01-05-2013, 12:47 PM
Mr.G6's Avatar
0/11 sssss4614
hatchback box sub up port back ALWAYS NEVER failed me
stick with a good amount of port area ( 13 to 15" per cube is ideal) take the total port area and divide that by volume and u get the "inches per cube" adjust port size accordingly
2.5 net and 32hz is a good start like i said use a good amount of port area
and double up the baffle where sub will be
2000 Gmc Sonoma ext cab
help with first time "REAL" box in 240sx hatch joemon Enclosure Discussion & Design Construction Help 23 05-03-2012 08:36 PM
Hd3 18 In the hatch Need help with box!! skipp3 Enclosure Discussion & Design Construction Help 10 04-23-2012 12:56 PM
kerfed port box build for my 240sx twisted Build Logs 18 12-24-2010 03:00 PM
pix of fiberglass box for 2 10s in a 240sx Buddah_iii Off Topic Chat 1 06-10-2010 09:11 PM
Nissan 240SX wiring harness FS canyouhearmatt Wiring, Electrical & Other Installation Equipment 0 01-21-2009 03:37 PM
