¿¿¿Port compression??? - Car Audio Classifieds!
Old 01-05-2013, 04:47 PM
KEVGNAR's Avatar
0/11 ssssss928
Default ¿¿¿Port compression???
Is there a rule of thumb or formula for port compression? I have some ideas id like to try and need to figure out what would be best
Even though this is definitely not built for numbers, demos speak a thousand words...
1990 Oldsmobile Cutlass Cruiser
Old 01-05-2013, 04:50 PM
rule of thumbs suck, you get to do a ton of math for anything in this hobby if you want it done right.
before I go further, what is your definition of "port compression?"
I want to make sure your talking about what I think you are
The Following User Says Thank You to korey_hofer For This Useful Post:
iamsonic (01-05-2013)
Old 01-05-2013, 06:22 PM
KEVGNAR's Avatar
0/11 ssssss928
I guess like port velocity, i made a new port for my box and it did nothin, im trying to lower tuning. I have a 36 for daily and it plays into the mid twenties well, but the one i made is longer tuned to 28 and wont play low for some reason, my woofers act like they are over-excurting. I have a 42hz port and it plays everythin above 30. Like i wanted it to do.
My ports are all the same port area, just different legnths
Old 01-05-2013, 06:44 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
its to hard to measure
does your port bend ?
does it load near a wall of the box?
does it load near a boundary in the car?
how much power you plan on using ?
do you have a flared port end ? if not port noise will be more audible
there are place on line that have some graphing and math to understand it but in car audio all bets are off its a whole new world when your roll up the windows or open a door or hatch
Old 01-05-2013, 07:48 PM
KEVGNAR's Avatar
0/11 ssssss928
It could be in part that its 13degrees out, and air desinty is raping me lol
Old 01-05-2013, 07:58 PM
HACKMUNCH's Avatar
0/11 sssss3892
This might help ya. http://www.aes.org/e-lib/download.cf...94&name=harman
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Compression driver slowpoke General Car Audio Discussion & Questions 3 11-02-2011 09:49 AM
horns and compression drivers psychoacoustics Component & Coaxial Speakers 22 12-16-2010 04:47 PM
FS: 15", 3.5 cu ft, 32 hz compression subwoofer box uglydimple12 Wiring, Electrical & Other Installation Equipment 11 08-27-2010 06:38 PM
Compression driver w/o a horn linden General Car Audio Discussion & Questions 2 08-25-2010 05:24 PM
