best box for a diamond audio d9 15 - Car Audio Classifieds!
Old 01-13-2013, 05:25 PM
0/11 sssss1364
Feedback Score: 25 reviews
Default best box for a diamond audio d9 15
so i have two of theses and was planning on using both but may just run one. what would you do a 4th or 6th simple ported for a single or use both. it doesnt matter if i dont use both . i want to murder the lows best if possible but have sql. i have a arc audio 2k that i can use with 1 as they are d2 subs or i can get another amp that will do .5 or 2 ohms. whats your thoughts i have 8 cubes to work with and the dimensions are 16 height 33 wide 32 depth
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Old 01-13-2013, 05:35 PM
0/11 ssss31257
I would either use both sealed OR just one in a 4th order.
Old 01-13-2013, 06:17 PM
0/11 sssss1364
wouldnt the sealed box not hit the lows?
help with diamond audio d9 12 box assassin1840 Enclosure Discussion & Design Construction Help 4 02-18-2012 12:28 PM
diamond audio esoteric audio boards uniqueautosound General Car Audio Discussion & Questions 7 09-30-2011 03:59 PM
diamond audio esoteric audio boards uniqueautosound General Car Audio Discussion & Questions 0 09-19-2011 10:30 PM
2 15" diamond audio d915d2 new in box sancho20 15" Subwoofers 5 04-28-2011 10:50 PM
Diamond audio tdx12d4 box help wahvtec Enclosure Discussion & Design Construction Help 9 07-21-2010 04:04 PM
