Half Walls - Car Audio Classifieds!
Old 01-14-2013, 12:21 PM
younggunzbass01's Avatar
0/11 sssss1653
Default Half Walls
Has anyone ever had good luck with one? Particularly in a 4 door. Just curious to see whats out there.
Ginger Filternator Impala Wagon pt. 2
12 12's
10k
Build log here
Old 01-14-2013, 12:33 PM
1loudyukonxl's Avatar
0/11 sssss1569
From what i have seen and the ones i have done the problem with them is they are loudest doors open and trunk open with sucks for daily driving enless you seal the trunk off but this is just my experance
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 01-14-2013, 12:35 PM
0/11 sssss1653
I did one in my old car, and i had the trunk sealed off. It did alright.
12 12's
10k
Build log here
Old 01-14-2013, 12:43 PM
SWIFT's Avatar
0/11 ssssss656
What is a half wall? Its either a wall or its not...
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
The Following User Says Thank You to SWIFT For This Useful Post:
kingsuv (01-14-2013)
Old 01-14-2013, 12:59 PM
0/11 sssss1653
Errr. I guess the definition would be a box in the backseat area. Most likely either subs up port forward, or vice versa. Id say only applies to cars.
12 12's
10k
Build log here
Old 01-14-2013, 01:04 PM
0/11 ssssss612
Exactly!
Half wall is to sound half cool.
Yahoo IM - kingsuv00
If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out.
Old 01-14-2013, 01:06 PM
Quisdccc's Avatar
Awaiting Confirmation
0/11 ssssss355
What about something like this?
Old 01-14-2013, 01:22 PM
0/11 ssssss386
loudest one I heard and have seen was two 15s in a 4 door civic with the subs up and port firing back into the trunk. So the trunk was not sealed off and he basically had a big aero port going back to with in 12 inches of the rear of the trunk. I think he also tried subs forward and mentioned the subs up was slightly louder. If I remember right, he was doing low 152's with a door or window open and meter on the dash legal position. I thought about doing the same but then it seemed like you might as well just wall it because you would probably have to build the box in the car anyway to do it right.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 01-14-2013, 01:46 PM
badmofo529's Avatar
0/11 sssss3329
There's no such thing as a "half wall" silly
Sent from my HTC Inspire 4G using Tapatalk 2
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 01-14-2013, 02:02 PM
tacomaguy1's Avatar
0/11 sssss4401
do something like this....look on his channel for more views of box
Hairtrick w/ 3 Sundown Nightshades - YouTube
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Are walls always louder? Wingman0121 General Car Audio Discussion & Questions 22 05-03-2012 06:42 AM
sealing off walls sundown General Car Audio Discussion & Questions 16 04-26-2012 02:27 PM
Guys With Walls, Help SpeakerBox General Car Audio Discussion & Questions 21 02-08-2010 03:48 PM
Walls 350zkid General Car Audio Discussion & Questions 39 03-05-2009 06:53 PM
