Wall dilemma - Car Audio Classifieds!
Old 01-14-2013, 05:58 PM
0/11 sssss3526
Default Wall dilemma
I am planning on walling 4 15s and have sufficient volume due to depth, but because my car is small, I dont have very much width. Its so tight that the gaskets of the subs would literally touch the gasket of the adjacent sub. I have just enough width to account for side mdf widthes, port width, and OD of the subs...Is this cutting it too close?
The specs that I have are 13.4cu after disp, @31.5hz, 190sq in of port, 14^2. Subs are Obsidian 15s to be wired to a DD m3 at .5
Any thoughts? Thanks for your input
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 01-14-2013, 06:44 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
go down to 3 cubes per sub. give yourself a little more wiggle room. as for phsyical space, as long as it fits it will work.lol
-Youtube Channel
Old 01-14-2013, 07:43 PM
0/11 sssss3526
Im kind of confused. How can the 12cu rather then 13.4 help me in my predicament? My main concern is having everything crammed width wise and Im at my max width. 1/2" less width and it wouldnt even fit at all. Unless you are implying that 12cu will be easier to achieve port area and I can lessen my port width?
Team Flex Issues
Temp build
Xs Power
Old 01-14-2013, 07:46 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Yes it could help free up your dimensions some. It makes no difference if its tight width wise. Long as it fits
-Youtube Channel
Old 01-14-2013, 07:49 PM
0/11 sssss3526
Oh ok, thats my main concern...It essentially goes side wall, sub, sub, port, side wall with the gaskets of subs literally touching. If that isnt an issue then Im gonna run with it.
Team Flex Issues
Temp build
Xs Power
Help: The Dilemma tntahoe General Car Audio Discussion & Questions 12 01-11-2013 09:37 AM
In a dilemma 20Hz_And_Below General Car Audio Discussion & Questions 14 04-26-2012 04:03 PM
I got a dilemma!!!!!!!! munches4bass General Car Audio Discussion & Questions 7 09-07-2011 09:37 PM
dilemma korey_hofer General Automotive Chat 15 08-02-2010 05:09 AM
In a bit of a dilemma Ryan1126 Off Topic Chat 9 04-04-2010 12:53 AM
