box suggestions - Car Audio Classifieds!
Old 07-24-2009, 08:53 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
Default box suggestions
well, i took all of my equip. and mock up box out of the stang, and im starting over with an emphasis on building a loud sql/spl daily driver, so im inclined to get as many opinions as possible on an ideal box size and tuning for my adire subs, the old box was a 5.5cuft slot ported wedge tuned to around 32hz, i dont know exactly where it peaked at but by ear it was around 30hz, im not asking for design specifics, just displacement, port area and length, and placement of drivers,.... im a carpenter by trade so i can extrapolate and build a design with ease with only those 4 factors i need....
im going slot, ported tuned to near fs, with bout 800w rms per driver and am unsure if i should do seperate enclosures or a common chamber, dual port or single on the common chamber, reason i ask these about the box is due to using 1" lexan for the baffle/s and rear, possibly even so far as to heat the lexan to form bends
the driver specs are; 12" adire audio mkIV brahma d4
fs:25 hz
qms:7.4
qes:0.54
qts:0.50
vas:52.7L
re:2 x 3.3 ohm
le:2 x 0.34 mh
sd:436 sq cm
bl:19.0 n/a
xmax: 28.5 mm one way linear
pmax: 600 w
spl:84.6 db
id figure it out for myself, but winisd is greek to me
any help will be greatly appreciated, and all suggestions considered,.... (help me get into the lanes, guys!!!)
thanx
who wants a nudel ride?
Old 07-24-2009, 09:21 PM
0/11 ssss31258
Old 07-24-2009, 09:26 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
Originally Posted by iamsonic View Post
wheres the f'n rep system when you need it!!! lol
Old 07-24-2009, 09:42 PM
you don't use winisd pro?
Old 07-24-2009, 09:53 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
i try to, but im just not very savvy to it yet, plus my laptop is pretty old, so it has probs freezing up on me all the time, it gets really frustrating at times for me cuz i chose to work in a non computer field for most of my working life, its kinda like tellin a i/t to build a house, just wont happen due to lack of knowledge in that field
Old 07-24-2009, 09:55 PM
I was talking to sonic
Old 07-24-2009, 09:59 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
my badd mayun, lol, it was misleading
sub and sub amp suggestions! Andrew General Car Audio Discussion & Questions 28 06-15-2009 04:07 PM
amp suggestions ???? bones22 Off Topic Chat 43 06-09-2009 03:43 PM
Need suggestions craiggus365 General Car Audio Discussion & Questions 3 05-11-2009 09:39 AM
Suggestions. 350zkid General Car Audio Discussion & Questions 10 03-18-2009 06:44 PM
box suggestions? peas247 Enclosure Discussion & Design Construction Help 2 03-05-2009 09:41 PM
