Noob Box Q's... - Car Audio Classifieds!
Old 07-25-2009, 06:50 AM
0/11 sssssss44
Arrow Noob Box Q's...
This is my first attempt at building a box so go easy...
I'm going to be putting 3 JL 10w6 subs in a single box but I'm not sure if I should make it sealed or ported.
Can anyone help me decide which way to go?
I plan to put this in a daily driver & I listen to everything music wize...
I was looking at the "free design sticky" and wanted to know if this box would be best suited for my subs?
Would the port be big enough?
http://gs171.photobucket.com/groups/...z56sqin6nx.png
Here's the specs for my subs, look at the 10w6 recommendations http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf, if I have to multiply by 3 wouldn't that be a monster of a box?
I don't know if I am doing something wrong but they recommend a box 51" x 36" x 41.25" with a 9" x 55.8" port ? ? ? does that sound right
Also... should these share a common chamber or should I separate the chambers?
Is the "Fs" (23.2Hz) what the box should be tuned at?
Like I said I know nothing about box building and I'm reading and trying to learn... I'd like to keep my mistakes minimal...
Thx in advance
Old 07-25-2009, 09:05 AM
DeadlySones's Avatar
0/11 ssssss318
I'd tune to like 30-32hz for them. What kind of ride is it going into? How much power you giving them? All you need is a box 3cu after displacements for the 3 10W6's ported, or 1.875cu sealed.....
What are your MAX dimensions to play with? Do you want to stick with round ports or go slotted? I can design you something. Unless Spy has something already.... don't want to be stepping on any ones feet.
Pioneer, AudioControl, Hertz, SounDigital, Sundown, Mmats, Power House, and a lil Princess Auto
149.9 Bass racer in a family minivan, sayyy whaaat?
Who needs to knock when you have BASS!!!
Old 07-25-2009, 09:10 AM
0/11 ssssss318
The dimensions you've listed makes a box that's over 39cubes... WOW. Little large for 3 10's IMO.
Give this a try, it should help.
Old 07-25-2009, 09:14 AM
0/11 ssssss318
ExtreameChevman's box looks like it would do the job! You could extend the port another couple inches at the back to get a little lower tuning.
Old 07-25-2009, 09:35 AM
hifonicsviii's Avatar
Loyal Member
0/11 sssss1423
it appears you multiplied each side 3 times,
If box requires 17x12x13.75 for each speaker, let say...As an example
keep the box 17 deep 12 tall then the 13.75 you multiply by 3 so end result would be a box...
17 x 12 x14.25 >>>edit...14.25 needs to change to 41.25 my bad
since you have 3 subs you multiply by 3, if you had 4 subs you multiply by 4 and so on..
556 positive feedback from 506 users on Ebay!!!
Paypal verified ..207..since 2004
Bought from- - ShiZZZoN - pieper88 -
Sold to - super_duper - lilkman2202
Old 07-25-2009, 09:37 AM
0/11 ssssss318
17 x 12 x14.25
Think you mean 17x12x41.25" not 14.25.
Old 07-25-2009, 10:00 AM
Loyal Member
0/11 sssss1423
Sorry I woke up up early after a hang over I got...LOl..thanks for that..I will add a small note on my post
Old 07-25-2009, 10:07 AM
0/11 ssssss318
Poor guy is confused enough ....
Noob mattinthebox New Member Orientation 14 06-12-2009 04:37 PM
NOOB tyler gray New Member Orientation 14 06-01-2009 12:27 PM
noob question for a not so noob installer. waresgaragestereo General Car Audio Discussion & Questions 5 03-31-2009 10:38 PM
Noob Here! fuknmovin New Member Orientation 21 02-13-2009 12:38 AM
noob jfink New Member Orientation 15 12-04-2008 08:03 PM
