4th order design - Car Audio Classifieds!
Old 01-16-2013, 01:22 PM
noknok's Avatar
0/11 sssss1521
Default 4th order design
I need help with a design for a blow threw. Box is 36deep 17 high and 48 wide outside dem. box is for 3 15s l5s kicker. With a front fire 8" port. Can someone help with the design thanks. Gunna tune to 38hz . Help please !!!
Old 01-16-2013, 09:15 PM
noknok's Avatar
0/11 sssss1521
I can go more on dept if needed.. Going in the bed of a truck
Old 01-16-2013, 09:24 PM
HiloDB1's Avatar
0/11 sssss3158
Just one 8" round port?
Old 01-16-2013, 09:26 PM
4ozgloves's Avatar
0/11 ssssss309
That's not nearly enough port space.
Old 01-17-2013, 07:07 AM
noknok's Avatar
0/11 sssss1521
What port area am I looking at??
Old 01-17-2013, 07:35 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
8 inch Aero is 50 sq... ideal is half of your cone area, so 260sq give or take for you... personally I've seen small ports work in blowthroughs but the builder knew alot more than me.
Sent from my DROID X2 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 01-17-2013, 07:53 AM
0/11 ssssss461
Agreed. The minimum port is 1/4 cone area; that's absolute minimum, which is 132 in^2 for 3 15's. I'd also tune quite a bit higher. 38hz tuning is going to kill from 15-40hz, but you'll have very little above 45hz. I'd start with a 45hz tuning if you like the lows, 50hz if you're looking for more 50-70hz output. A good starting point would be 6cf sealed, 12cf ported with 3 8" aeros or even better, two 10" aeros if you can find them. Again, this is just a good starting point. You'll probably have to play around with sealed/ported volume and tuning to get it perfect.
Edit: Based on your dimensions, you don't have enough room for three 15's in a 4th order. Could get away with two 15's though or three 12's.
Old 01-17-2013, 07:59 AM
Micksh's Avatar
0/11 sssss2596
Without running specs on them, I bet 6 sealed isn't big enough to get the resonant frequency low enough either... Definitely DO NOT tune below 45 hz or so, anything below that and you'll have no high bass at all....
My Youtube page
Astro build log link
Old 01-17-2013, 08:02 AM
0/11 ssssss461
Yeah, 6 cubes is the smallest I'd run. If they're all in a common chamber, I'd bet that would be very close to 50hz resonant frequency. But you're right, there's no way to know for sure without getting T/S parameters.
Old 01-17-2013, 08:13 AM
Silver-N-black's Avatar
0/11 sssss3544
Since he said he would be able to extend the D from 36. Would 40 Work? 42?
Not trying to jack your thread, I also was planing on running 3 15. Problem is I only have 48W20H40D which i'm told is not enough space. Just thing to learn a bit more.
Need a 4th order design BlackWaterOp Enclosure Discussion & Design Construction Help 2 05-15-2012 09:06 PM
$20 for a 4th order design right now via PP oxsign Enclosure Discussion & Design Construction Help 3 10-17-2011 11:14 PM
4th Order Design Help Silver-N-black Enclosure Discussion & Design Construction Help 9 08-24-2011 12:23 PM
First 4th order design AFlem Enclosure Discussion & Design Construction Help 20 04-29-2011 09:42 PM
4th order design bassbear007 General Car Audio Discussion & Questions 1 02-17-2011 07:57 PM
