Kerfing - Car Audio Classifieds!
Old 01-17-2013, 07:40 AM
0/11 sssss1513
Feedback Score: 17 reviews
Default Kerfing
How do you guys kerf, Table Saw, Circular Saw, Mitre Box, doing a first kerf this weekend. Looking for ideas.
Old 01-17-2013, 08:03 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Circular saw with blade set to about around 2/3s of material thickness(depending on desired bend of course)... I'm still a newbie to kerfs though
Sent from my DROID X2 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 01-17-2013, 08:12 AM
0/11 ssssss261
This should help
How to Kerf bend MDF for your subwoofer port! - DIYMA Car Audio Forum
Old 01-17-2013, 08:43 AM
0/11 sssss1513
Has anyone ever used a sliding miter box, seems to be easier than a circ saw
Old 01-17-2013, 08:44 AM
0/11 ssssss247
I use both table saw and circular saw, but it's much easier on a table saw
Old 01-17-2013, 09:46 AM
0/11 ssssss723
Feedback Score: 31 reviews
I may try this on a cnc mill soon
Ban me.then and.stop showing.his.childish the mods are here with these changes.to my sig
Old 01-17-2013, 11:18 AM
0/11 sssss1513
someone said try the sliding miter box, anyone think this is a good idea?
Old 01-17-2013, 11:23 AM
HiloDB1's Avatar
0/11 sssss3158
Sliding miter sled is probably the easiest/safest way to do this type of cut.
Old 01-17-2013, 11:27 AM
Mr.G6's Avatar
0/11 sssss4614
circular saw is all i need
2000 Gmc Sonoma ext cab
0/11 ssssss266
i think depth will be the issue with the miter saw
i use a circular saw and a t-square as a guide
is kerfing all that great? MERQUE Enclosure Discussion & Design Construction Help 5 04-06-2011 12:02 AM
2 15's in a center console LOTS of kerfing FLAstrongman Build Logs 31 09-28-2010 12:36 PM
Kerfing Question BassikInstincts Enclosure Discussion & Design Construction Help 0 01-06-2009 03:01 PM
