Ported box for 2 sa8's - Car Audio Classifieds!
Old 01-17-2013, 04:00 PM
0/11 ssssss176
Default Ported box for 2 sa8's
I've got a design started but I'm a little curious on the port. I'm not very educated when it comes to port design and how all the sound stuff works, and I was wondering if someone could give me some port dimensions that would be tuned to 35hz for a box that is 10"(h)x 8"(w) x 24" (l) for 2 sa8s. Thanks!
Old 01-17-2013, 04:34 PM
0/11 ssssss176
Design drawn to scale. 1" is 1 square. Would love some feed back. The box has to be these dimensions to fit behind the seats of my reg can truck, so I need input on port dimensions, sub placement, and port direction. Thanks!
Old 01-17-2013, 04:35 PM
0/11 ssssss176
I built my last box and was satisfied with it but I'm not so confident about this design. Want some input before I go slapping it together
Old 01-17-2013, 05:04 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
figure up your net volume and then click this link,
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
it has all your formulas you need for a ported box,
i would help with tha calculations, i just dont have the time at the moment
good luck
Old 01-17-2013, 08:24 PM
0/11 ssssss176
Bump!
Old 01-18-2013, 06:58 PM
0/11 ssssss176
Bump.
Old 01-18-2013, 07:24 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
I assume port area is a reasoning for the no response.
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 01-18-2013, 07:28 PM
sthrnbumpn's Avatar
0/11 sssss2961
sureal is a beast with 8's
Old 01-18-2013, 07:30 PM
Prohibited Sellers/Buyers
0/11 sssss1326
you dont have enough space for a ported box, it would be tight for just one in that space. just build a sealed box and rock it. its your best bet in that small area
Old 01-18-2013, 09:20 PM
0/11 ssssss176
My previous build was 1 sa8 in a ported box in the same truck and it was fantastic, I'm not settling for it can't be done because I don't believe that.
Anyone run SA8's in a sealed box? rideit (Sundown Audio) 11 05-04-2012 01:17 PM
Anyone use a sealed box for 2 sa8's? West1 Enclosure Discussion & Design Construction Help 5 12-04-2011 10:28 PM
what size box for 4 sa8's 98Expo (Sundown Audio) 4 05-29-2011 12:31 PM
e8's sealed or sa8's ported?? phensway General Car Audio Discussion & Questions 7 03-07-2011 05:16 AM
need box help for 2 Sundown sa8's!!! lugnut110189 Enclosure Discussion & Design Construction Help 18 11-14-2010 12:17 AM
