hatch back help - Car Audio Classifieds!
Old 01-18-2013, 07:59 AM
0/11 sssssss20
Default hatch back help
I'm going to build a box for a friend to go in his 2003 toyota celica. The box is for 2 sa 1`2's, I can get 4 cu ft after displacement and a port area of 64"..... 16" per cu ft tuned to 35htz. My main concern is woofer and port placement, I believe the best would be subs up port back, the issue is if I do that the port would be about 2" from the back of the car and I think it would restrict the flow. Would I be better woofers forward and port up,woofers up-port up or some other configuration? All help and opinions are appreciated!
Old 01-18-2013, 08:21 AM
jheist1991's Avatar
0/11 sssss1070
Could you do subs up, port to the drivers side? I've always had luck with that setup in my Mitsubishi eclipse.
Old 01-18-2013, 08:34 AM
0/11 sssssss20
the only place i can put the port on the box without restricting air flow is on the top...I have room for subs up/ port up....subs front/ port up...any configuration, just worried about the port being so close to the car body if I put it to the rear,side,or front.
Old 01-18-2013, 08:51 AM
jheist1991's Avatar
0/11 sssss1070
Ok no problem. You can put it to the back or side and the short space between the port and the wall will help with loading and it will drop the tuning a bit. I have my system subs up port back right now, 8 inch aero, tuned to 40 hz, firing back with around 1.5 inches space between it and the back of the trunk in my car, and it wangs pretty good from around 28-70 hz. With the SA's and decent power, it shouldn't hold you back to much though. Musical louder to the ear, I would go with port to the side or in the center between the subs firing up, metering volume, I have had more luck with port back tuned a bit higher than your looking for.
Here's a pic of what I'm running for reference since I doubt I made any sense above
Joseph Edward Heisterkamp's Photos | Facebook
Old 01-20-2013, 11:59 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I did port up and sub up in that car, it is loud. I wouldn't tune that high with those subs either, like 32-33 hz for how I'd like it.
Old 01-21-2013, 12:21 AM
ridintwo6s's Avatar
0/11 sssss1791
sujb up port up gets my vote
Old 01-21-2013, 08:06 AM
0/11 sssssss20
We went with sub up port up...4 cu ft after displacement,73.5 sq in port area,tuned to 35 htz. 2 sa 12 d4 run 1 ohm on a precision power D1000/1. works really well, should get better as the subs loosen up.........thanks for the help!!!
Old 01-21-2013, 01:42 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Is this for SPL? Why so much port?
2 12s or 1 15 in hatch back whats better spl and sql cvxsteve General Car Audio Discussion & Questions 3 05-26-2012 12:47 AM
Cyberknife's done, Back at work....Back on Caco Lol Jdubs04ss Off Topic Chat 0 10-26-2011 09:41 AM
focus hatch back help focusedfornow Enclosure Discussion & Design Construction Help 3 09-11-2011 07:01 PM
rebuilt top end, put distributor back in, suburban wont start. it back fires. kickerfanatic General Automotive Chat 7 09-01-2011 09:21 PM
New Rebuild: Back at ground zero , but im coming back harder splvictim20 Build Logs 898 10-20-2010 01:20 AM
