Design Needed... - Car Audio Classifieds!
Old 01-21-2013, 06:15 PM
newarkbeast973's Avatar
0/11 sssss7810
Default Design Needed...
I want to try to do a 4th order/bandpass for 2 10" dc xl m2's. I want something similar to this (see pics below)
Now I know in order to make this design you'll need some info. Im use to providing good info for a ported box but don't know what is needed for something like this. So what info is needed to help with the design?
thanks
New build coming soon!!
Old 01-21-2013, 06:20 PM
0/11 sssss3842
hit up Marcotheclepto.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 01-21-2013, 06:23 PM
0/11 ssssss759
hit up Evan (surreal) https://www.wooferwarehouse.com/Cust...gn-_p_123.html he just designe me a 4th order just like this for a pair of sa12s .. should be building this week..
Old 01-22-2013, 12:48 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
You could also try JT BUCK here on the forums. He is good at the 4th and 6th order designs.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 01-22-2013, 01:07 PM
0/11 sssss1898
You need to list the t/s specs of the subs and all available room cause this is going to be a big box
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 01-22-2013, 01:23 PM
Prohibited Sellers/Buyers
0/11 sssss1326
will need to provide max dimensions,
preferred freqency response
if you want it to blow through a skii hole need measurements of the skii hole as well as where its located in relation to the trunk ie x inches from left x inches from trunk floor.
may be esiest to draw a hand sketch of the skii hole and make notes on it.
Old 01-22-2013, 01:25 PM
0/11 sssss1326
will also need to know how much power you plan to run to them
Dad Needs Help, 6.5 Box Design Needed! BassikInstincts Enclosure Discussion & Design Construction Help 3 04-23-2011 08:59 PM
4th order design needed LivinLoud08 Enclosure Discussion & Design Construction Help 17 03-04-2011 06:01 AM
walkthrough design needed. Violence* General Car Audio Discussion & Questions 0 07-03-2010 05:18 PM
3 15" TC3000's DESIGN NEEDED ASAP jdubbau Box Requests 1 09-29-2009 02:02 PM
Box design opinions needed SPY Enclosure Discussion & Design Construction Help 13 09-12-2008 02:11 PM
