FI BL 18's 4th order wall? - Car Audio Classifieds!
Old 01-21-2013, 08:23 PM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
Default FI BL 18's 4th order wall?
Right now I have my bl 18's in a tline wall designed by surreal, box is 23 cubes before port, corners for tline and sub displacement. I am thinking of rebuilding as soon as it warms up to a 4th order wall. Car is 2012 scion xb, subs call for 5-8 cubes each. How many cubes sealed per sub and what ported would be a good place to start? I had a 4th in my expedition that was something like 4 sealed and 19 or so ported but wasnt a wall. Thanks for help, I may just end up paying for another design and going from there
2 FI bl 18's walled in 2012 scion xb
Old 01-21-2013, 09:34 PM
0/11 ssssss543
I'm not an expert on bps but from what I understand with 4ths you want to seal in whatever qtc alignment you normally would as if it were just sealed and the make the ported side either 2 or 3 times the volume of the sealed side tuned to the resonance of the sealed side. The lower ratio would yield a flatter response with less peak spl and the higher ratio would be more peaky, but overall louder. I would think 4ish on the sealed side and 8-12 on the ported side. The problem with this is that it may peak too high, as a bl would likey be much more suited in a quasi, or series 6th, than a 4th.
Again I'm no expert on bps so please don't start building off these statements unless it's experimental only.
Bought from - Hazardous0388 (4 db Drive 2000.1s), Psychoacoustics (4 Powerbass XA 3000'ds), and blackedoutavy (PPI A200)
Sold to - D-Rew (Knu 1/0), d77543020 (Knu 1/0), F1McLarenAGR (Audioque 4x90), and SacTownBully84 (Knu 1/0)
Traded with - SacTownBully84 (my xa3kd for his xa1.5kd + cash)
Old 01-22-2013, 09:06 AM
98Expo's Avatar
0/11 sssss1929
They did very good in 4th in other ride. I probably get Buck or surreal to do a design after I check all my measurements again
Old 01-24-2013, 01:45 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Do a 6th man!!!
Old 01-24-2013, 06:14 PM
98Expo's Avatar
0/11 sssss1929
let me get some measurements this weekend, and I will go from there. I dont know what im doing for sure, lol
6 psi 18's in a 4th order wall tommytee Build Logs 28 02-27-2013 02:29 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 08:37 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 03:01 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 06:50 PM
Stay ported or try 4th order bandpass wall for 4 18's?? 46panel General Car Audio Discussion & Questions 7 05-17-2011 02:19 PM
