9515i 4th or 6th - Car Audio Classifieds!
Old 01-22-2013, 11:01 AM
0/11 ssssss112
Default 9515i 4th or 6th
A customer is bringing me 4dd 9515i and a cadallic ext. Definatly doing a blow through but im not to familiar with these subs from what i can tell spec wise the motor is decent and suspension is stiff. but specs are just specs how do they do in the real world with real power? Anyine done 4th with these?
Old 01-22-2013, 11:06 AM
mbrooky's Avatar
Team South
0/11 sssss1238
I was told the i series soft parts are 4th order friendly. 6th order will definately work.
TEAM SOUTH bishes
TEAM RedStick
Team Hz Addiction
sa8 4th order trunk build:
Old 01-22-2013, 11:13 AM
0/11 ssssss461
Same here. I think either would work well with the i series; especially in the 15/18 sizes.
Old 01-22-2013, 11:36 AM
0/11 ssssss112
Alright then looks like ill shoot for a 4th with a nice ratio. they rate em at 1500 but what will they rally take ?
Old 01-22-2013, 11:46 AM
0/11 ssssss461
Depends for how long you're dishing it out and how clean the power is. For full-length song demos: don't go above 2k clean. For 30-second demos: 3k. 5-second burps: who knows? Just a general guideline.
Old 01-22-2013, 11:50 AM
0/11 ssssss112
Probably keep in the low 2k range per on paper and let the rise work out the rest in that case.
Old 01-22-2013, 03:54 PM
mbrooky's Avatar
Team South
0/11 sssss1238
this is 4 9518s in a 6th order i built on one m4a. haven't tried them in a 4th but are beast in a 6th.
DD Yukon - YouTube
TEAM SOUTH bishes
TEAM RedStick
Team Hz Addiction
Old 01-22-2013, 04:14 PM
HACKMUNCH's Avatar
0/11 sssss3892
anyone know about t/s parameters? subs have them so you dont have to GUESS lol
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 01-23-2013, 08:27 AM
0/11 ssssss127
I have an old f series motor with an I basket aaSnd parts and I like it, I usee a old silver m3 at .5 and I am not nice to it. It takes a full clip for a whole 2 minutes in the low 12v range before it starts to stink. Now I want to do a 4th...
Old 01-25-2013, 01:53 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Do a 6th.
4th or 6th order wall hdman87 Enclosure Discussion & Design Construction Help 38 09-16-2011 03:16 PM
need a 4th or 6th order design Xtremelegend Enclosure Discussion & Design Construction Help 3 06-26-2011 04:47 PM
6th order VS 4th? Shutdownaudio General Car Audio Discussion & Questions 1 02-14-2011 08:57 PM
4th/6th order advantages jws84_02 General Car Audio Discussion & Questions 1 11-15-2010 05:15 PM
4th or 6th order help treylittlefield Enclosure Discussion & Design Construction Help 28 10-14-2010 04:48 PM
