box design for 2 hdc3 10s on 4k - Car Audio Classifieds!
Old 01-24-2013, 04:18 PM
0/11 sssss8594
Feedback Score: 55 reviews
Default box design for 2 hdc3 10s on 4k
box is right around 3cu, single 8" aero tuned to 38hz...aero is gonna stick out 11.25" for daily, and 2.75" for burps (45hz burp)...2 4" 45s in corners, 3 2" dowels front to back...gonna be for 2 hdc3 10s on 4k...should do some work
but heres my question...im fiberglassing the inside and considered adding 3 more 2" dowels...one would go side to side and the other 2 would be top to bottom (pics will show)...is that too much in the way for airflow or will i be fine because they are rounded??...it would drop me down to about 2.8-2.9cu net
Enclosures
Old 01-24-2013, 04:48 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You don't really need them.
Old 01-24-2013, 04:49 PM
0/11 sssss8594
the fiberglass should be fine with only the 3 dowels??
Enclosures
Old 01-24-2013, 04:55 PM
0/11 sssss4519
should be just fine.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 01-24-2013, 04:58 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Ya man, you'll be fine. That box isn't that big.
0/11 sssss8594
what about my port...the top of it will be right on the top of my box...should i lower it a little bit or use a 45 to make for smoother air into the port from the back wall??
Enclosures
Old 01-24-2013, 04:59 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
How far is the port from the rear wall?
Old 01-24-2013, 05:00 PM
0/11 sssss8594
4"...half the diameter of my port
Enclosures
Old 01-24-2013, 05:01 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Meh, that's uncomfortably close.
Old 01-24-2013, 05:02 PM
0/11 sssss8594
how far would u go??...full 8"?
Enclosures
box for hdc3 10s...too big? fyerbyrd22 Enclosure Discussion & Design Construction Help 12 11-28-2012 10:40 PM
4 DD 3500g 10s Box Design ndgamer Enclosure Discussion & Design Construction Help 2 06-08-2012 07:51 AM
Box Design for 4 DC 10s bigdogjk Enclosure Discussion & Design Construction Help 0 02-14-2012 08:51 PM
box design help (9 10s) Sniper General Car Audio Discussion & Questions 3 02-05-2011 12:57 PM
Box for HDC3 10s input tez4life General Car Audio Discussion & Questions 8 06-06-2010 05:37 AM
