6 15'' mtx 8000's - Car Audio Classifieds!
Old 02-01-2013, 10:02 PM
richdog102's Avatar
Handing out Pimp slaps!!!
0/11 ssssss925
Default 6 15'' mtx 8000's
they are going into my 05 silverado ext cab....no back seats doing a wall need help deciding on 3 cubes each ported or 2 cubes each 4th order...playing low 30's only used for ground pounding...here is a link to the pdf ...http://archive.mtx.com/caraudio/prod...ubs/T8154A.pdf
Old 02-01-2013, 10:15 PM
zombie killer
0/11 ssssss290
I would do 2 smaller box bigger port more air
Old 02-01-2013, 10:21 PM
richdog102's Avatar
0/11 ssssss925
not sure what you exactly mean...sorry can you explain ...thanks
Old 02-01-2013, 10:37 PM
zombie killer
0/11 ssssss290
Yea smaller the box is the bigger you will have to make the port so it will push more air out and the subs wont get hot as fast
Old 02-02-2013, 12:00 AM
richdog102's Avatar
0/11 ssssss925
oh i understand what you were saying....yeah i know that. i have about 20 cubes to work with i was just looking for which size box ported or 4th order from the specs will i get the most output. i see by their graff the bigger the box the best results....the biggest forth order looks best on their graff
Old 02-03-2013, 03:54 PM
richdog102's Avatar
0/11 ssssss925
anybody else have any input?
Old 02-03-2013, 03:56 PM
0/11 sssss4519
You don't have the space for a 4th IMO. Go ported
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 02-03-2013, 03:59 PM
richdog102's Avatar
0/11 ssssss925
but if you look at the graff them 4th order specs are small
Old 02-03-2013, 04:04 PM
0/11 sssss4519
that's 2 cubes per driver sealed. so 12 cubes sealed only leaves you with 8 ported... Unless I am seeing that wrong.
resolve Vas/28.32 =
result of that +1
Old 02-03-2013, 04:09 PM
richdog102's Avatar
0/11 ssssss925
the biggest 4th order is 2.42 cubes max vol... 1.07 sealed and .97 ported...before displacement..am i wrong? not sure if i am translating it right..
MTX 9500 15'' for 180? 1-12-t1 General Car Audio Discussion & Questions 5 10-25-2011 11:19 PM
15'' treo next to custom 15'' sundown night shade. kickerfanatic General Car Audio Discussion & Questions 3 05-17-2011 05:51 PM
[SOLD] 15'' mtx rfl anj46907 15" Subwoofers 9 12-15-2009 02:23 PM
