Side firing port - Car Audio Classifieds!
Old 02-03-2013, 03:49 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
Question Side firing port
So in my desire for a certain sound this is my next step in trying to find it lol.
Side firing port (driver side) looks to be enough port area and tuning is decent just not sure how this style box is going to sound in my hatch, guess I will find out when I build it. Box is shown with double baffle, and 3 1&1/4" pine dowel braces, I did NOT sketchup the 45 in the back but it will be there.
Thoughts? Opinions?
Oh and this leaves around 5-6" of space on the port side of open space.
2017 Lexus ES350 SQL Project underway.
Old 02-03-2013, 03:56 PM
0/11 ssssss461
I have the same setup in my Edge. Sounds great. Sounds better with port facing passenger side, but it depends on the vehicle.
Old 02-03-2013, 04:04 PM
98GMC's Avatar
0/11 sssss1265
I had great luck doing side firing in my truck. Leave enough room for the port and I would say you should have good luck.
Old 02-03-2013, 04:20 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
5-6" of open space from the port wall to the side of the car, and this is for 12s if I didn't mention it.
Old 02-03-2013, 04:42 PM
Ronmeister's Avatar
0/11 ssssss791
Port to passenger side would probably be louder to your ears, but since it is symmetrical I'd play around with it. I used to flip mine around between comps and daily lol.
I'm sure you will enjoy the new woofer/port orientation. Will this be woofers firing up or rear? Will or is the loading area for the port symmetrical across the entire width or depth depending on how you plan to lay it out? Lol
This is two 12" drivers on 2.5kW? Equipment from your sig I gather?
Old 02-03-2013, 05:33 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
2 12s, they will not be whats in my sig and the amp is a Skar Sk4500.1.
Old 02-05-2013, 03:48 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
So decided to do some work today and get this box going, so got off my butt this morning and started cutting here is what I got done.
Old 02-05-2013, 03:50 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
Continued!
The next few pics show the bracing test fitting, I may change it around a little before doing it for good, will definitely be putting the second baffle on and cutting sub holes before doing them final for sure.
More tomorrow!
Old 02-05-2013, 07:30 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
I couldn't just stop for the day so I got the back on and the 2nd baffle.
Nothing like roughly 100lbs of weight to help hold her down!
Old 02-05-2013, 08:27 PM
0/11 ssssss247
Not diggin the design
question about L port and center firing port fyerbyrd22 Enclosure Discussion & Design Construction Help 10 10-10-2012 05:51 PM
Port and Sub firing question younggunzbass01 Enclosure Discussion & Design Construction Help 0 02-08-2012 04:49 PM
Suv side firing port question? murderedtahoe General Car Audio Discussion & Questions 7 11-27-2011 04:17 PM
Side firing in SUV jt_buck Enclosure Discussion & Design Construction Help 38 12-02-2010 11:46 AM
