thoughts on my sa-10 box? - Car Audio Classifieds!
Old 02-05-2013, 08:19 AM
0/11 sssssss19
Default thoughts on my sa-10 box?
I've decided to try a ported enclosure for my sa-10 just for kicks.
I'm thinking 1.0ft^3 tuned to around 33hz.
I'm not set on 33hz, it's somewhat of a guess as to what may sound good - I'm going for sq more than spl and listen to all genres so I need it to give me the accurate punch of rock as well as the lows in rap.
My box is limited to a size of 8"d x 13h x 33"w
The sub will pretty much be right up against the rear shelf of the car behind the passenger seats in a porsche 911 so I was thinking it would be better to go with a side firing aeroport over a rectangular port.
My box would measure roughly 8"d x 12.5"h x 31"w, making it 1.12ft^3 after sub displacement, this would be subject to change based on the displacement of the aeroport (which I don't know yet).
Using PSP's port calculator, with a 4" aeroport, I would need a port length of 25.8" to tune to 33hz. I'm afraid the sub would interfere with a port this long.
So, am I on the right track here or just way off base?
Can aeroports be configured to be that long?
Old 02-05-2013, 08:46 AM
hotzie's Avatar
changin the game up
0/11 ssssss793
do you already have the 10 cuz if not id go with the sa8, in that space you will be much happier imo.
also how much power will you be runnin to it, and was it in a sealed enclosure prior?
Old 02-05-2013, 09:19 AM
0/11 sssssss19
Yes, unfortunately I already have the 10 and it's in a sealed enclosure right now. I wish I would have known I was going to try ported, I would have gone with an 8.
I can run up to 700rms @ 2 ohms to it.
Old 02-06-2013, 09:54 AM
0/11 sssssss19
Well the 4" aeroport will be too long and hit the sub so it's been recommended that I put a 180 degree turn in it like so:
The problem is I'm not sure how to make the bends or what materials to use.
I can't use a 3" port, which would work length-wise, but I will have way too much port compression.
It's also been suggested to me to use a passive radiator setup but I have absolutely no experience with these and am not quite sure where to begin.
Any suggestions?
Old 02-06-2013, 01:14 PM
all4spl's Avatar
Graphics Freak
0/11 ssssss408
PVC elbows at homedepot/lowes can give you the turn you are wanting.
2017 Lexus ES350 SQL Project underway.
Thoughts...? Scapelli21 (Sundown Audio) 16 02-05-2011 03:54 PM
Thoughts and opinions on a box design n023b General Car Audio Discussion & Questions 27 12-21-2010 10:35 AM
I need your thoughts.. SPL_II Off Topic Chat 17 06-18-2010 11:07 AM
thoughts and suggestions on this box? dylan9999 General Car Audio Discussion & Questions 5 04-30-2010 10:15 AM
Thoughts on box for LMS-4000 RollerDJ Enclosure Discussion & Design Construction Help 19 03-13-2009 02:51 PM
