Design Help - Car Audio Classifieds!
Old 07-28-2009, 03:41 PM
bigeasy79's Avatar
0/11 ssssss977
Default Design Help
I am designing a box for my friends RE SX 12" he wants it tuned around 32 hz (going in a 2 door accord).
This is what i have so far.
If you can't read the measurements they are
Width: 21
Height: 14.5
Depth 22
Port opening: 2.5
Long port: 18.75
Short port 8
Im also planning on doing 45s in the corners but im not sure how to figure out how much air space they will take up. Is there a formula for this?
Anything i need to change or add?
Old 07-29-2009, 10:00 PM
bigeasy79's Avatar
0/11 ssssss977
Bump
Old 07-29-2009, 11:52 PM
bass_lover1's Avatar
0/11 sssssss30
Same way you find volume of the box, you can find the volume of displacement, LxWxH / 1728 (assume you're measuring in inches).
A rough guess would be 14.5" (was that an internal or external measurement?) x .75" x somewhere around 3 maybe? So maybe .02 cubic feet per angle.
- Alpine CDA-9887 - AudioControl DQS - Linear Power 652I - B&G Neo3 - Clarion DPX 2251 - Vifa XT18 - Clarion DPX 1851 - Alpine SWX-1243D -
Old 07-30-2009, 06:17 AM
98AckCL23's Avatar
0/11 sssss9929
A 45 is a triangle. So to find the volume, it's .5*base*height. Or .5*Side length 1*side length 2. That will give you the area of the triangle, then you multiply by the interior height of the box to get the volume that the 45 will take up.
Also, if you 45 the port, it changes the port length. See Pioneer~Saturn's writeup in the tutorials for that calculation...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 07-30-2009, 10:09 AM
0/11 sssssss30
Good call, I was only accounting for the wood it self, and not the entire volume it displaces.
This is why I pay someone to build boxes for me
Old 07-30-2009, 02:29 PM
98AckCL23's Avatar
0/11 sssss9929
Even then, it's a trapezoid, not a square. So the volume formula would be (base 1 + base 2)/2 * .75 * interior height of the box.
<- engineer, so...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 07-30-2009, 04:02 PM
0/11 sssssss30
<- engineer, so...
I knew that, but figured even the board it self only displaces .02 cubic feet, shaving off a 45* angle IMO isn't going to make a noticeable difference. However, if we were talking about something more important, then yes I agree.
Old 07-30-2009, 04:42 PM
98AckCL23's Avatar
0/11 sssss9929
You'd be surprised how much volume some big 45's take up... I know I've had to compromise on 45 size in order to keep volume up and tuning down before...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 08-02-2009, 11:43 AM
bigeasy79's Avatar
0/11 ssssss977
Thanks for all the help.
This is what i came up with Its supposed to be 2.1 ft^3 tuned to 32hz with 32.5 port area. Should that be ok for a SX 12"?
Old 08-02-2009, 12:04 PM
DeadlySones's Avatar
0/11 ssssss318
Looks good.
Pioneer, AudioControl, Hertz, SounDigital, Sundown, Mmats, Power House, and a lil Princess Auto
149.9 Bass racer in a family minivan, sayyy whaaat?
Who needs to knock when you have BASS!!!
box design for 4 sr-15s???? CTIPPINS General Car Audio Discussion & Questions 35 03-02-2009 10:23 PM
Box design anyone? Buddah_iii Enclosure Discussion & Design Construction Help 5 02-04-2009 09:53 PM
Box Design Help... Blackout Enclosure Discussion & Design Construction Help 4 01-22-2009 06:01 PM
my design korey_hofer General Home Audio/Video 9 12-26-2008 08:58 PM
Need help with my box design thecartel Enclosure Discussion & Design Construction Help 10 12-12-2008 07:02 PM
