Need box recommendation for 2 SA-12's for my s10 Blazer - Car Audio Classifieds!
Old 02-09-2013, 06:17 PM
bosco2023's Avatar
0/11 sssssss60
Default Need box recommendation for 2 SA-12's for my s10 Blazer
Ok, I was working up a box for a Re sx 18 when the eBay seller decided to bail out and not ship my sub. So I bought 2 new sundown audio sa12's. Im gonna be powering them with a hifonics 2000d at 1 ohm. Which realistically with my 200 amp alt , 1/0 wire, and 2 agm's in rear should net me 1600-1700 rms. The subs are going in a 02 s10 blazer fired up and port rear on drivers side if that sounds ok. Tuning I
don't know. I listen to alot of lil boosie, webbie, waka, ti and music like that with occasional colt ford and newer country. My max dimensions are 23" high, 23" deep and 37" wide. 23" deep allows me 8" from box to tailgate with rear batteries. I have 3/4 mdf already and will be doubling the top baffle. I like the side slot port as I can build that pretty easy. Bottom port is a little more difficult. Also a cut sheet would be awesome. Thanks guy in advance.
Old 02-10-2013, 12:34 AM
bosco2023's Avatar
0/11 sssssss60
Woot woot
Old 02-10-2013, 12:44 AM
Jfool289's Avatar
0/11 ssssss254
[email protected] 80sqin of port
Old 02-10-2013, 12:49 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
too much box for SA's IMO. I run my sundown 12's in 1.5 net per sub. It's efficient. Power handling is good. Is a bit peaky though. I'd tune to around the lowest stuff you play. Maybe like 3cube at 32
-Youtube Channel
The Following User Says Thank You to taylorpro For This Useful Post:
tony30cl (02-10-2013)
Old 02-10-2013, 10:07 PM
bosco2023's Avatar
0/11 sssssss60
anyone else thats has sa12's?
Old 02-10-2013, 10:11 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
get torres box calc or re box calc for a easy cut sheet
tune low
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 02-10-2013, 10:13 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Originally Posted by skartisu View Post
tune low
meh.
-Youtube Channel
Old 02-10-2013, 11:22 PM
bosco2023's Avatar
0/11 sssssss60
Originally Posted by taylorpro View Post
meh.
I watched some of your vids, do you remember the specs on the box you built for your friend and then had it in your green station wagon for the vid on that 1500?
Old 02-10-2013, 11:53 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
yep 3 cubes net. one 6" aero tuned at 35. that was going in a trunk so subs were forward and port was to the side
-Youtube Channel
Old 02-11-2013, 01:38 AM
bosco2023's Avatar
0/11 sssssss60
Could you do me a design for subs up and 6" port to drivers tuned to 32/33 hz maybe 3.5 cubic foot using my dimensions above? I would really appreciate it.. More than you know. I know your time is in your system, but I need someone who knows their stuff. I see that you do. Im not bsing here. I want it to be right the first time and I give credit where its do. My amp is so so on output. Want to step up to 2400 rms when I can. Plenty of bass heads around here to sell my old hifonics amp. When I went to Carslile import a year ago I got to see the team DC audio guys come down from NY and those guys were amazing for what they were running. I seen 2 dc lvl5 12's subs in an explorer straight tear shit up and was speechless. 2 years ago I got to sit in the jeep ragtop of a member of team dc with 4 15's and was floored by the output.
[SOLD] Q Logic QForm S10/S10 blazer kickpanels 99xtremedime Wiring, Electrical & Other Installation Equipment 3 02-02-2013 02:45 PM
Thorbecke Bros Bolt in S10/S10 blazer bag cups 99xtremedime Miscellaneous Stuff For Sale 0 02-01-2013 09:30 PM
HX2 12's in my S10 Blazer SQLAudio Uninterrupted Build Logs 0 08-15-2012 01:15 PM
91 s10 blazer seleniums92 Build Logs 5 08-10-2010 07:57 AM
93 S10 Blazer Help. Kicker Guy General Automotive Chat 4 03-09-2010 11:48 PM
