Port firing onto amplifiers - Car Audio Classifieds!
Old 02-11-2013, 09:42 PM
richdog102's Avatar
Handing out Pimp slaps!!!
0/11 ssssss925
Default Port firing onto amplifiers
I have 8 15's going into my silverado bed blowthrough into the cab. Is it ok to have the port blowing right onto my amplifiers. Like is the vibration going to damage the internals or is the amps going to be ok. I figured the wind from the port would help with cooling. And also i have no where to mount all the amps really except in front of the port.
Old 02-11-2013, 09:44 PM
0/11 sssss8594
Feedback Score: 55 reviews
as long as its not DIRECTLY in front, like an inch away from the opening, and its mounted to something sturdy and vibration resistant, you should be fine
Enclosures
The Following User Says Thank You to fyerbyrd22 For This Useful Post:
richdog102 (02-11-2013)
Old 02-11-2013, 09:49 PM
richdog102's Avatar
0/11 ssssss925
Atleast 6 to 10 " away. The would ne mounted to the floor of the cab on a fkase floor bolted to the rear seat oem bracket mounts so real sturdy. Should i use rubber between the mounting feet of the amps and the fase floor or is the mount to the false floor fine? I just thought port wind would cause the vibration. So the only really vibration i have to worry about would be like a loose amp moving around on its mounting posion correct?
Old 02-11-2013, 10:00 PM
younggunzbass01's Avatar
0/11 sssss1653
Use as many rubber/foam/padded spacers as you can. But ive done setups like this plenty of times with no issues.
Ginger Filternator Impala Wagon pt. 2
12 12's
10k
Build log here
The Following User Says Thank You to younggunzbass01 For This Useful Post:
Old 02-11-2013, 10:05 PM
richdog102's Avatar
0/11 ssssss925
Cool. Thanks guys
Side firing port all4spl Enclosure Discussion & Design Construction Help 27 02-09-2013 05:16 PM
question about L port and center firing port fyerbyrd22 Enclosure Discussion & Design Construction Help 10 10-10-2012 05:51 PM
Port and Sub firing question younggunzbass01 Enclosure Discussion & Design Construction Help 0 02-08-2012 04:49 PM
Suv side firing port question? murderedtahoe General Car Audio Discussion & Questions 7 11-27-2011 04:17 PM
