Input on my 6th orders... - Car Audio Classifieds!
Old 02-11-2013, 11:53 PM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
Default Input on my 6th orders...
Subs: FI BTL (ufo) 2 x 15s
6th order blowthrough
rear (left) ~8 cubes tuned to 30hz 8" aero (50" of port)
front (right) ~12 cubes tuned to 60hz. ~375" of port.
worried more about the second design, i like the first better...
Old 02-12-2013, 12:03 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
2nd wouldn't be well...ports fire thru each other... id make the rear chamber tuned a lil higher too
How much power btw?
Old 02-12-2013, 12:07 AM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
i was thinking more towards 32-34 too. i dont need it to kill the lows i want it to be musical.
power is a bc3500 @ .7
thank you very much.
Old 02-12-2013, 12:17 AM
Authorized Vendor
0/11 ssss14115
33 ...Use and L port instead of a aero if u can... put the port as far from the front as u can as well as the subs... then throw a small 45 degree in the back corner opposite of the rear chambers port (from the pics its the back right corner)
Old 02-12-2013, 12:18 AM
0/11 ssssss767
The top box for sure as far as lay out goes. Do you have a cap for the bed yet, because from my measurements you will need to bevel your sub baffle kinda like Nick Watts did his. Just wondering about the cover becouse I've been curios as to whether it will give a little more room.
Old 02-12-2013, 12:30 AM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
its on its way, i just got a cheap snap on/tri-fold one. to the top of my bed is 16.75 so im gonna make it as tall as i can. should have enough i hope. im hoping the cover will give me a little more height well see though...
Old 02-12-2013, 12:35 AM
0/11 sssss1230
Drop front port area to 250-275 max.
Team Excessive
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
would an L port against the rear wall be best? then the subs in from there? and i gotcha with the 45s...
the only reason i was going to do an aero was for tuning ease. my plan is to use all thread and make the baffle "moveable" to change the ratio then mess with the port size's might save that for a second box...
0/11 ssssss767
Good luck man I'm tuned in for your build I got some similar plans I'm just collecting product.
The Following User Says Thank You to 150orbetter For This Useful Post:
Wood. (02-12-2013)
Old 02-12-2013, 12:37 AM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
okay i was just going off a rule of thumb i saw posted elsewhere that said 28-35' per cube.
i dont have any knowledge in this stuff at all, just kinda shootin from the hip...
so really any and ALL input is greatly appreciated...
whos good a designing 6th orders around here? IAWJ4.7 Enclosure Discussion & Design Construction Help 22 01-06-2013 07:40 PM
6th orders.... lets shed some light on the subject Miles General Car Audio Discussion & Questions 49 12-25-2012 08:42 PM
6th orders- teach me robman General Car Audio Discussion & Questions 0 12-23-2012 02:31 PM
school me on 6th orders Help is needed Plz!! lilsoccersully General Car Audio Discussion & Questions 0 10-10-2012 05:53 PM
I know you said no more orders. But.... newarkbeast973 Toolmaker Price Quote Section 4 03-15-2012 12:32 AM
