Center port help - Car Audio Classifieds!
Old 02-11-2013, 11:58 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
Default Center port help
I can use RE for a basic 1-sided port, but how do you determine the port length when its a ceter port that splits left/right? my port is 4"wide from the baffle, so do I make the splits half of that (2"w port) in the left/right split, and just go as long as the total port length is?
EX: if my total port length called for 20", and i go 10" from baffle and make the bends start once I reach the 2" mark for my ports. Do I.....
A) Go 10" for each bend
or
B) Go 5" for each bend?
My box is 11"h, 52"w, 13"d. The subs and port will be on top (SUV 3rd row, 2 SA-8s).
Audiopipe Nutthuggery at its finest
Old 02-12-2013, 10:55 AM
0/11 ssssss855
Look up Torres box calculator on google its on smd so much more accurate then re audio one that would allow you two common port walls and allow you to see port area per cf tuning add sub displacement
Old 02-12-2013, 05:10 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
I've got torres, but can't figure it out that well.
question about L port and center firing port fyerbyrd22 Enclosure Discussion & Design Construction Help 10 10-10-2012 05:51 PM
Subs up port back... port in center or on bottom???? oxsign Enclosure Discussion & Design Construction Help 2 08-20-2012 11:01 AM
how to figure up center port 98Expo Enclosure Discussion & Design Construction Help 3 06-19-2012 01:50 AM
Tuning center L slot port apbt55 Enclosure Discussion & Design Construction Help 0 09-11-2010 12:07 PM
center port box ? CLNFREAK Enclosure Discussion & Design Construction Help 9 05-01-2010 11:47 AM
