single hcca 15 design help - Car Audio Classifieds!
Old 02-12-2013, 01:17 AM
0/11 ssssssss9
Default single hcca 15 design help
So my cousin got his hands on a orion hcca 15 and a hcca d5000.1. The box its currently in is damage by water. The new box will be in his new daily (07 Ford Explorer). We are trying to build it within the next few days. I was going to use RE calc but ive heard its not accurate. Sub up port back? sub and port face rear? A local said 3.5 cf net tuned to 32hz would be perfect(sub up/port back). hitting lows are a must for this build. Please somebody help! we are fiending for bass.
Old 02-12-2013, 06:38 PM
0/11 ssssssss9
Can someone check this for me to make sure its right. 35" width x 15.5" height 21" depth. With a port of 14"h x 4.5" width x 30" length. should be tuned around 32 hz. Looking for around 4.5cu ft net.
Old 02-12-2013, 06:53 PM
Jfool289's Avatar
0/11 ssssss254
Actually re box cal is right on, i compared it to 12v when designing a box. all you have to do is displace the subs and you should be fine
Need a box design for single SA-8 v.2 d2 Boomintahoe Enclosure Discussion & Design Construction Help 23 03-19-2013 06:26 PM
need a box design fr a single sa-12 tattoonick87 Enclosure Discussion & Design Construction Help 0 06-04-2012 08:04 PM
Need diff amp for my single 12" Orion hcca cu0ngsayz Wanting to Buy (WTB) 18 11-30-2011 12:18 AM
Single 15 Box design? xpd442 Enclosure Discussion & Design Construction Help 7 03-22-2011 12:49 AM
Hcca 12.2 box design? Dunbar91 Enclosure Discussion & Design Construction Help 0 11-11-2010 08:32 PM
