2 sa12 in Jeep Grand Cherokee - Car Audio Classifieds!
Old 02-14-2013, 08:56 PM
0/11 ssssss273
Default 2 sa12 in Jeep Grand Cherokee
I need box specs for 2 sa12 in a Jeep Grand Cherokee. I want a ported box and was thinking firing up port back? Or firing up and port up? Please some input.
Grand Cherokee
Mechman 240, Mechman 270, 4 runs 2/0, d3400 under hood, 6 31's agm in rear, 4 silver flute 6.5, 8 vifa 1", 2 sk85.4, 2 zvx 18, 2 sk2500.
Too much electrical is better then not enough.
Suburban build coming soon. Collecting parts.
Old 02-14-2013, 09:05 PM
bamapride427's Avatar
Active member
0/11 ssssss488
In my wj port back subs up does the trick
Old 02-14-2013, 09:07 PM
infaredsinsor's Avatar
0/11 ssssss769
Subs up, port back or subs back, port back. Tune around 38 and those SA's will beat with authority.
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 02-14-2013, 09:23 PM
e2theloc's Avatar
0/11 ssssss909
what amp?
150+ Club
Follow me on Twitter!! @e2theloc
Old 02-15-2013, 04:45 AM
0/11 ssssss273
Im looking at a couple amps on here. Skar sk1500, sundown saz1500 or planet audio bb2400.
Grand Cherokee
Old 02-22-2013, 06:51 AM
0/11 ssssss273
To update I'm running the 2 sa12d4 on a skar 2500
Grand Cherokee
Old 02-23-2013, 01:09 PM
0/11 ssssss273
Members
So here is a suggestion port/subs on the same face:
Enclosure Specifications:
Fb = 30.029 Hz
Vb = 3.346 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 15 in
External Width = 38 in
External Depth = 18.75 in
Port Width = 3 1/2 in
Cut List:
* All Dimensions in Inches.
* Wood Thickness is 3/4 for all Parts.
External Enclosure Parts:
Front = 33 3/4 x 13 1/2
Front Internal = 32 1/4 x 13 1/2
Back = 38 x 13 1/2
Left & Right Sides:
Side 1 = 17 1/4 x 13 1/2
Side 2 = 18 x 13 1/2
Top & Bottom = 38 x 18 3/4
L Port Internal Assembly Parts:
Front to Back = 13 3/4 x 13 1/2
Extension = 16 x 13 1/2
How well would this box perform with 2sa12d4 on a skar 2500?
Grand Cherokee
Old 02-23-2013, 01:13 PM
Mr.G6's Avatar
0/11 sssss4614
wont sound good at all if you dont have electrical to support that amp
2000 Gmc Sonoma ext cab
Old 02-23-2013, 01:49 PM
0/11 ssssss273
Well its all in the works. Amp is enroute should be delivered this week and have been talking to singer and should have more stuff on the way from him.
Grand Cherokee
Old 04-20-2013, 07:08 AM
0/11 ssssss273
Well electrical is almost done. Mechman 240 installed with 2/0 from alt to bat. Now going to do ground from alt to chassi and batt. Already ran 2/0 from front to the rear and slowly putting it together. I work 60hrs a week so its a little tight at times.
Grand Cherokee
Jeep Grand Cherokee Thread! Kidthump General Car Audio Discussion & Questions 362 06-22-2014 07:54 PM
340 Amp Mechman alternator for jeep grand cherokee 6.1L or 5.7L jeep commander Mnorwood01 Wiring, Electrical & Other Installation Equipment 16 12-29-2012 10:09 PM
My 2000 Jeep grand cherokee dat517boi Member Rides & System Pictures 38 07-10-2011 05:13 PM
ALT for '01 Jeep Grand Cherokee 4.7? krunchbubble General Car Audio Discussion & Questions 7 01-04-2011 02:36 PM
