04 cavalier trunk build single 18" - Car Audio Classifieds!
Old 02-16-2013, 02:15 AM
0/11 sssssss26
Default 04 cavalier trunk build single 18"
Ne one have ne ideas on a build. I plan on puttn my nightshade v2 18 facing forward with a 10" port. Sealed off from trunk so my cabin space is smaller. Box needs to be around 6 cubes after defuctions. Limitations on box size is 34 wide and 17tall. Top plate 28 deep n bottom plate 34 deep so the sub will have a slight slant to it but way better than it firing torwads the trunk lid. Ne input is appreciated. Thanks. Once again my car is a 2004 chevy cavalier 4 door. Im runnin a nightshade v2 18 with b3 spiders on a skar 2500 at .5 ohm clamped about 3300 watts
Old 02-16-2013, 03:05 AM
BassJunkie's Avatar
0/11 ssssss565
Not sure how you intend on fitting that facing forward with only 17" of height. The opening for that trunk is only like 16" tall and is pretty important to the structural integrity of the car. I would go with a single 15. And plan on building inside of the vehicle or cutting sheet metal. Largest i could get in my sunfire trunk without building inside was a 4.5ish cube box.
Old 02-16-2013, 03:21 AM
0/11 ssssss254
i second that bass junkie
Old 02-16-2013, 03:41 AM
0/11 ssssss386
Fiberglass tub in the spare tire well and you will be building piece by piece in the trunk. It can be done, I did it in a 94 accord. Not sure if your spare tire well comes forward far enough.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 02-16-2013, 04:18 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Stick to 2 12s or a 15.
An 18 in an ideal optimal box just wont happen in that trunk, got a friend who is dieing to put an 18 in a 97 Cavalier 4 door and it just cant happen.. at least if you plan on keeping a fully functional back seat.
Old 02-16-2013, 05:52 AM
younggunzbass01's Avatar
0/11 sssss1653
Stick with a pair of 12s. Subs firing forward into the cabin. Ported sideways into the driver side wheel well. Prepare to be amazed.
Ginger Filternator Impala Wagon pt. 2
12 12's
10k
Build log here
Old 02-16-2013, 08:07 PM
0/11 sssssss26
I seen an 18 in a trunk if a cavalier on youtube. I was thinkn maybe to slant the front baffle so tht a 20" baffle would fit in 16" of height. The port would have to be a bit external of course. Here the link of tht cavalier i seen on youtube
My XXX Cavy flexing just a little bit - YouTube
Old 02-16-2013, 08:08 PM
0/11 sssssss26
I will be running in meca trunk class also
Old 02-16-2013, 08:46 PM
vince79vette's Avatar
0/11 sssss2011
My girl has a 04 cav and they biggest box i could do is 5 maybe 5.5 cubes. And it just fits. I have about 6 ins from the back of the trunk.
I wish u luck man i would like to see one in a trunk of a cav doing some good numbers.
Sent from Chuck Norris foot
Old 02-16-2013, 08:48 PM
cav950015s's Avatar
0/11 ssssss745
2 12s front firing with port firing forward is best I have found did a 150 sealed up with dd9512gs reconed by psi and sd 8k.did a 147.3db sealed with with ss xxx 15 and sd 8k.trying side firing now no where near as loud and I also run a 2004 4 door cavy bro and I have tried a lot of different stuff bro.two 15s didnt breath for shit lol.12s are best bet.
2004 chevy cavalier ls sport.double din pioneer head unit.two deka batteries in the trunk.3 runs of zero gauge and 3 300 amp fuses.sound digital 8k amp.two dd9512gs.4 cube box tuned to 40 hrz with 8 inch aero port firing into cab 150 is best i have done sealed up so far.took 3rd place at world finals 2012 1001 to unlimited class.
Cavalier trunk Ujerk123 General Car Audio Discussion & Questions 17 02-11-2012 12:25 AM
147db @ 33hz with a single 15" Z ina Trunk! jnralp00 (Sundown Audio) 44 02-19-2011 11:06 AM
2000 Cavalier single sub setup QuikZ24 Build Logs 13 11-23-2010 11:39 PM
Kyles random Build log. 2010 Genesis 2011 mustang 4 15" cavalier tahoefixssd Build Logs 46 11-10-2010 07:12 AM
Cavalier Trunk Won't Open andes11 General Automotive Chat 2 10-24-2010 03:32 PM
