Wall help! Grand Prix gtp! - Car Audio Classifieds!
Old 02-17-2013, 07:07 PM
0/11 ssssssss9
Default Wall help! Grand Prix gtp!
Hey guys, well to start I want to put my dc audio lvl 4 in a wall in the back of my 2 door 2000 Grand Prix gtp but I have no idea where to start! How should I go about this and I'm not sure how I'm suppose to drill the screws in from the bottom, top, and sides to hold it together. Any help there? And where would be the best place to put a port? I would like the sub between the front two seats. If any of you could just give me a bunch of pointers that would be great!! Thanks!
Old 02-17-2013, 07:33 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
you dont wall one sub
-Youtube Channel
Old 02-17-2013, 07:40 PM
0/11 ssssssss9
How do you think I should go about this? I mean, I could build a box inside my trunk but I couldn't go ported because I won't have enough space. So I could go sealed but I would have to build it in the trunk to get 5^3 ft out of it but idk how to screw it all together... How would I do that?
Old 02-17-2013, 07:43 PM
maverickdog8's Avatar
0/11 sssss2979
I would at least do 2 15s.
Build the box to spec of the size you need and slide it into the car, mount it, and do a beauty panel in the front to seal it. That's what I would do at least in a gtp. I got lucky and ended up using a 4 door Grand Prix. Lol
Old 02-17-2013, 07:44 PM
0/11 sssss2979
You can fit right around 7 cubes in the Grand Prix trunk, but you have to build it in the trunk and its a tight fit.
Old 02-17-2013, 07:45 PM
0/11 ssssssss9
I forgot to Mention it's a 18", sorry.
Old 02-17-2013, 07:46 PM
massivespl's Avatar
0/11 sssss8409
you can wall a single subwoofer.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 02-17-2013, 07:48 PM
0/11 ssssssss9
I mean, ill build the box in the trunk but I have no idea how I'm going to screw it together. And how good would a sub pointing up in a trunk sound?
Old 02-17-2013, 07:50 PM
massivespl's Avatar
0/11 sssss8409
my buddy has a 15 in a buick and its sub up port back works great... i bet u can build a 5-6 cubic box out of the trunk and slide it in.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 02-17-2013, 07:53 PM
DLP customs
Guest
0/0 sssssssss
Its very possible to do. Is your trunk gutted? Like have you took out all the sidewall carpet etc? If not do that first. Then get a box design done by somebody here and build it in your trunk. If you cant screw it just use glue and clamps and you have to play the waiting game for it to dry properly. Dont start slamming on it untill about 24 hours after so the glue can dry fully. If you dont use screws of course.
Grand prix rebuild! maverickdog8 Build Logs 145 07-17-2012 08:37 PM
Drsnazzy 2004 Grand Prix Gtp drsnazzy Member Rides & System Pictures 3 01-17-2012 06:47 PM
04 Grand prix Setups? drsnazzy General Car Audio Discussion & Questions 15 01-03-2012 11:37 PM
04 grand prix mythyone General Car Audio Discussion & Questions 0 07-10-2010 08:10 PM
My 08 Grand Prix. itsbmw Member Rides & System Pictures 5 10-16-2009 06:12 AM
