Scion frs 2 12 inch Orion hcca 12.4 - Car Audio Classifieds!
Old 02-18-2013, 02:39 AM
0/11 ssssss437
Default Scion frs 2 12 inch Orion hcca 12.4
Dimensions I have are 34 width 14.5 height 20.5 depth. Would this size box work for daily/spl. I want it tuned around 33 hz but I can't get a port worked out tuned that low.
Old 02-18-2013, 08:55 AM
0/11 ssssss437
Bump really need some help on this one.
Old 02-18-2013, 09:18 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
with the dimensions you have to play with it looks like you don't have enough airspace for 2 hcca subs.each sub needs like 2.5-3 cubes and your gross volume is only 4.38 cubes. then you take away from that for the port and you wind up around 2.92 cubes net with tuning around 34ish. your best bet is to do a single hcca or get 2 sa-12 subs and you would be fine doing this size box as they only require 1.5-2 cubes each.
My game is legit,
Old 02-18-2013, 11:24 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
your inbox is full
My game is legit,
Old 02-18-2013, 12:32 PM
0/11 ssssss437
well the manual for hcca subs say 1.5 net cu ft per sub
2013 scion frs 2 12s or 1 15 423bass General Car Audio Discussion & Questions 6 02-07-2013 01:39 AM
10 inch Orion HCCA with custom box Wingman0121 Craigslist Deals 3 09-11-2012 02:05 AM
orion hcca ring 10 inch ellocojorge Speaker Accessories & Parts 9 08-16-2011 03:59 AM
