Good Plywood from Lowes - Car Audio Classifieds!
Old 02-20-2013, 01:55 PM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
Default Good Plywood from Lowes
Being I only have a Lowes within reasonable distant from me, what is some good plywood for box building that I can use in substitute to MDF? I don't mind using MDF but I hate the dust it creates. Can someone get on Lowes' website and point me in the right direction? Thanks.
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 02-20-2013, 01:57 PM
SWIFT's Avatar
0/11 ssssss656
How do you have 3500 posts and NOT know this answer?
MDF or Birch, they will have Birch. Only 5-7ply but it will be fine.
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
0/11 ssssss350
Their 3/4 inch Birch plywood is the lowest I would use. They also have maple and oak plywood but its more $$$.
Old 02-20-2013, 02:26 PM
0/11 ssssss855
Cabnet grade Pyle wood will work for what you want to do ive built my wall my friends box for his single 18 ans soon ro be a 6th for two 18s I dont see a point in paying for the two layers of "birch" the inner layers are Pyle wood anyways
Old 02-20-2013, 03:59 PM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
My lowes doesn't have birch ply. Only home depot.
Old 02-20-2013, 04:50 PM
Austin175's Avatar
0/11 sssss4224
Mine has birch but it's like 60 or more a sheet but home depot which is an 1hr an so away has 3/4 mdf for $35 a sheet but not worth driving for.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 02-20-2013, 05:00 PM
0/11 ssssss106
I'm not sure if Lowes has it but I just built a box out of Arauco pine plywood and it turned out great. I bought it at Home Depot, if Lowes has it give it a shot, it's $28.97 a sheet here in KY.
Old 02-20-2013, 06:37 PM
0/11 sssss3819
I have always used MDF and nothing else. I have been wanting to venture into plywood for boxes but never knew what makes certain plywoods good. I know birch is the way to go but I'm not spending 75 bucks a sheet for what Lowes wants.
Tweeters: Vifa XT25
The Following User Says Thank You to MopaRBumpiN For This Useful Post:
Austin175 (02-21-2013)
Old 02-20-2013, 06:39 PM
you don't have to use birch, that "birch" is only a veneer anyway. The ply's are pine. I've been using red oak for mine.
2 gift card lowes and Home depot SMFJ31721 Miscellaneous Stuff For Sale 4 01-12-2013 10:32 PM
Awesome Circular saw @ Lowes $40 SPLEclipse Hot Deals 22 06-20-2012 11:54 PM
Dremel Drum sander bit .84 at Lowes SPLEclipse Hot Deals 0 02-27-2012 10:14 PM
lowes peal and seal videos before and after cjbellmore Sound Deadening & Fabrication 55 03-25-2011 01:47 PM
Can you get glue for a recone at lowes ? richardparker General Car Audio Discussion & Questions 10 09-10-2009 09:04 PM
