single sa12 box help??? - Car Audio Classifieds!
Old 02-20-2013, 09:49 PM
Brand New Members
0/11 ssssssss3
Talking single sa12 box help???
I need some help building a box for a single sa 12 dual 2 ohm, its going in a 02 envoy, the amp is a rockford fosgate t 1500 1 bdcp at 4 ohms '1000rms', slot port or areo? size? placement of sub and port any help would be awsome !!!!!!
Old 02-20-2013, 10:06 PM
0/11 sssssss67
Use a single 4" aero in 1.75-2 cubes net. Tune 30-35. Sub forward port to the side gives you multiple firing options. What kind of vehicle?
Old 02-20-2013, 10:09 PM
0/11 sssssss67
Nevermind... I didn't see 02 envoy. I would still do that set-up
Old 02-20-2013, 10:36 PM
Brand New Members
0/11 ssssssss3
02 gmc envoy , what the advantage of a areo port over a slot port?
Old 02-20-2013, 10:38 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Easy adjustable tuning.
Id do a 6" aero though....and like 2-2.25cu, should tune ya around 38hz.
Sub back port side
Youtube VIDz :
Old 02-20-2013, 11:14 PM
Jfool289's Avatar
0/11 ssssss254
Sub back port side
How do you calculate displacement of an aero port?, like if I wanted a box net to 4.2 ft3 with a 6" areo tuned to 32hz?
Old 02-20-2013, 11:23 PM
0/11 sssssss67
For 4.2 ft^3 net at 32hz a 6" flared port would need to be 14.3" long.
Old 02-20-2013, 11:34 PM
Jfool289's Avatar
0/11 ssssss254
Ok, but what would be the displacement of the port so I can add displacement to my box, so far with my subs its 4.6ft3?
Old 02-20-2013, 11:51 PM
0/11 ssssss318
3 cubes gross 6" aero. itll get down. mine does. sundown wont advertise this but sa-12s like 2-2.5 cubes go model it. you shall see
EDIT a full length psp aero 18" i wanna say is .3 cubes. 4 is kinda larger for one drive tho. sub up port side you can pull off 3 cubes and an aero, id tune 32-36ish. my buddy has and envoy plenty of space.
Old 02-20-2013, 11:57 PM
Jfool289's Avatar
0/11 ssssss254
Actually, it was for 2 12" subs, 3 cubes gross is way too small
Single SA12.....burping....LEGAL n USACI Skip01 Car Audio Videos 37 02-09-2013 12:26 PM
box for sa12? need advice please akrja_07 Enclosure Discussion & Design Construction Help 14 10-27-2012 08:36 PM
Single sa12 on a Stetsom 14k Skillz (Sundown Audio) 21 02-07-2012 08:56 PM
single SA12 tuned to 30hz Skillz (Sundown Audio) 0 03-11-2011 04:47 PM
Sundown SA12 + Prefab Box laserred97gt 12" Subwoofers 15 12-28-2010 03:42 AM
