2 18 zcon 6th order will this work? :) - Car Audio Classifieds!
Old 02-21-2013, 02:15 PM
0/11 ssssss855
Default 2 18 zcon 6th order will this work? :)
trying to see if this desgin will work if not what would be needed to make it happen
the subs will be two 18 inch zcons powered my a 40.1
on to the box
rear will be
tune: 27 hz
space : 13.73 cf
port area 116^2
per cf 8.45
front
tune 56 hz
space 23.74 cf^3
port area 522 in^2
per cf 21.99
pics of said design
Old 02-21-2013, 02:44 PM
Infinitelybaffled's Avatar
0/11 ssssss816
Yes. What's the port length on the front port? I would start using 2x4's around 56hz and shrink it till you stop gaining spl at whatever frequency you want.
Inappropriate sig image.
Old 02-21-2013, 03:12 PM
0/11 ssssss855
does this seem right?
port area :754.00 inČ
per cf 43.23
net volume 17.44
tune : 55.72 Hz
Old 02-22-2013, 12:40 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Looks good man. I would just add some bracing.
Old 02-22-2013, 12:46 AM
0/11 ssssss767
Lightbulb
I agree as far as design it looks good and add some bracing. I've seen boxs like this do very well.
I could be wrong but I thought zcons were more geared for a 4th.
Old 02-22-2013, 01:00 AM
0/11 ssssss855
Thanks and I plan on adding steel bracing in the rear and the major planes of the box
I post ts specs and hank I belive saod they were a 6th order sub or ported they would work in a 4 just not ideal
Old 02-22-2013, 01:17 AM
0/11 ssssss767
I got ya I just thought that becouse Nick Watts has 4 in a 4th order blow through in his s/10. From what I remember he had good luck but it seamed like he needed way too much power.
Old 02-22-2013, 01:26 AM
0/11 ssssss855
Yeah I seen that he has something like an everest 5k to each but it does sound bad ass on music lol
4th order or 6th order kingtidis Enclosure Discussion & Design Construction Help 5 05-29-2011 11:05 PM
