Input on my box design? - Car Audio Classifieds!
Old 02-23-2013, 03:12 PM
0/11 sssssss45
Default Input on my box design?
I want to run my DD 9515 in my M3 and im thinking going aero port instead of slot is this a good design
End result with another piece of 3/4 inch mdf so the sub is flat mounted as well as a cool design
Old 02-23-2013, 03:21 PM
1 6" port tends to out flow 2 4's, other then that looks good.
Old 02-23-2013, 03:25 PM
0/11 sssssss45
Will 1 6 inch be enough for a DD 9515? To my understanding the DD 9515i pushes A LOT of air.
Old 02-24-2013, 12:30 AM
are those 6" ports in your design? if they are look into a single 8"
usually the less amount of ports you have the better as long as the area is close.
Old 02-24-2013, 01:35 AM
0/11 sssssss45
theyre 4 inch ones but i can move the sub over to the right a bit and then use whatever port size/port(s) you recommend i would like to keep it 8 or under though
Old 02-24-2013, 02:22 AM
Austin175's Avatar
0/11 sssss4224
whats the dimensions on the box an what tuning are you aiming for?
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 02-24-2013, 02:29 AM
Prohibited Sellers/Buyers
0/11 sssss1326
a single 6 would be ideal. and slightly more port area than a pair of 4s. 2*pi*r^2
so 4pi per 4 inch and 9 pi per 6 inch.
box design looks fine, just remember to keep port width away from rear wall. and also that the port will be about 50% larger than diameter at the flares (6 inch is 9 + inches wide and 4 inch is 6 + inches wide)
Old 02-24-2013, 05:53 PM
0/11 sssssss45
box Length=32 Top width=14 Bottom width=22 and Height=17 1/2
Place for my amp= Length=24 Depth=3 Height=10
I would like to end at 37-38 Hz with 1-2 6" aero ports.
Old 02-26-2013, 07:49 PM
0/11 sssssss45
to the top
Input on box design for Hatchback mdaudio General Car Audio Discussion & Questions 12 10-11-2011 10:00 PM
Single 15 Box Design.Any input ? xpd442 Enclosure Discussion & Design Construction Help 9 04-02-2011 01:46 AM
box input please! jimmay Enclosure Discussion & Design Construction Help 8 09-06-2010 09:57 PM
Need input on this box design k3n12ock General Car Audio Discussion & Questions 19 02-24-2010 01:41 AM
