Input please. Does this look decent. - Car Audio Classifieds!
Old 02-24-2013, 02:40 AM
0/11 ssssss214
Default Input please. Does this look decent.
Just designed this box. Wanted to know if it all looks good. I didn't put the extra baffle on the front in Torres because I recessed the speaker. I equated for it it and designed through sketchup with the extra baffle. Tuning frequency will be 1hz higher because of this. And port per foot will go to 15.00. Also wanting to put wooden dowels for some more support in the box that was equated for.
Let me know! Thanks
Sent from Rezound using Tapatalk 2
Old 02-24-2013, 08:45 AM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
you did pretty good on the sketch as far as i can tell,
58 1/2 is kinda wide,
i was trying to imagine any vehicle big enough to house that, other than a suv
it would hard trying to slide that in a trunk opening
The Following User Says Thank You to sthrnbumpn For This Useful Post:
TampaVmax (02-24-2013)
Old 02-24-2013, 09:31 AM
0/11 ssssss214
It's a Silverado ext cab. And Ty btw.
The Following User Says Thank You to TampaVmax For This Useful Post:
sthrnbumpn (02-24-2013)
Old 02-24-2013, 09:35 AM
sthrnbumpn's Avatar
0/11 sssss2961
yw, hit the little thanks button on the bottom right of my post
Old 02-24-2013, 09:46 AM
0/11 ssssss214
I shall when I get on a comp. Tapatalk won't let me. As far as the port goes. Did I do it correctly in Torres? When I make the port bend do I act like the length is just for one side and match them like I did? Also, do I just take half the main port size an make that distance from back wall? (port is 5.5 now each speaker has a 2.75)? I'm guessing all this is correct but I wanted to be positive.
Old 02-24-2013, 09:51 AM
sthrnbumpn's Avatar
0/11 sssss2961
i figured it out to be 26 1/4 long port, according to the inside wall of port,
but your suppose to add a certain amount to that, to get an actual centerline of port dimension,
which is your actual port length
Old 02-24-2013, 09:52 AM
sthrnbumpn's Avatar
0/11 sssss2961
27 1/2" actual length
Old 02-24-2013, 02:43 PM
0/11 ssssss214
Then I guess its good... Good deal. If anyone else has some input let me know.
i need a decent 10 tankglh21 Wanting to Buy (WTB) 20 12-20-2011 09:41 AM
decent 2/0? btsteinb General Car Audio Discussion & Questions 5 11-02-2011 01:14 PM
Decent Deal djarmy2004 Bargain Bin 5 03-15-2011 09:41 PM
Decent two input three out passive EQ/SP rideit Wanting to Buy (WTB) 4 03-11-2011 06:16 PM
decent? korey_hofer General Car Audio Discussion & Questions 5 08-18-2009 11:48 AM
