Need help with 4th order c-pillar or just a regular box for the back of a 99 explorer - Car Audio Classifieds!
Old 02-26-2013, 10:48 PM
0/11 sssssss99
Default Need help with 4th order c-pillar or just a regular box for the back of a 99 explorer
Can't decide if I want to do a 4th order c-pillar or a sub up port back box in the back of my 99 explorer. Around 14 cubic foot or maybe a little bigger depends. tuned around 32-34 hertz. it is for 2 18" aq hdc3s on a soundstream rubicon 2500.1 for now. i need a box design or at least rough ideas about what it should look like
Old 03-07-2013, 08:22 PM
0/11 sssssss33
Not enough room for a 4th for 2 18s dude. Youde be better off with either a flat wall or ported box
Old 03-07-2013, 08:32 PM
Austin175's Avatar
0/11 sssss4224
Ya I agree cause I was gonna do a 4th for 3 15"s but there is not enough room in my jeep to do it. So the next best thig is a c pillar wall or a box in the cargo.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 03-07-2013, 09:00 PM
Veteran Member
0/11 sssss3359
14 cubes gross? You'd be at 12 or better gross for a 2 18 wall
Old 03-14-2013, 03:41 AM
ridintwo6s's Avatar
0/11 sssss1791
he could probably get a low ratio ( 2:1 ) in that space, but would be very tight .... not to mention those subs BLOW for 4ths.
id stick to a ported wall or cargo box ...
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
10 15's in a 4th order going in the Explorer 46panel Build Logs 125 09-03-2012 01:05 PM
Designing c pillar wall/4th order Austin175 (Sundown Audio) 45 08-31-2012 11:53 PM
American Bass Ford Explorer 4th order (one of my current up and coming projects) ssaudio Build Logs 27 10-25-2011 12:47 PM
46panel's 4th order wall in the Explorer 46panel Build Logs 205 10-25-2011 02:00 AM
