Ford ranger blowthrough help - Car Audio Classifieds!
Old 02-27-2013, 11:20 AM
BASS14's Avatar
0/11 sssss1086
Default Ford ranger blowthrough help
So im goin friday to pick up a bed cover finally, and i wana do a blowthrough, i have 2 15" ssa XCONS and a cactus sounds k5 for power. Idk nothing bout blow throughs would like some form of a 4th or a 6th order. If anyone could give assistance on designing a box that would be awesome along with how big of a hole ill need in the truck lol
Subs-2 15" SSA XCONs
box-Huge 4th Order BlowThrough
Deck-Kenwood KDC-X996
Amp-Cactus Sounds K5 wired at half ohm
Wireing-knukonceptz through out
Battery(s)-2 NGT Extreme NG31s project db terminals
Old 02-27-2013, 12:29 PM
0/11 sssss3842
Here's one I done for 2 SA12s in a buddies ranger. Marcotheclepto designed the box....I built it.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 02-27-2013, 03:23 PM
BASS14's Avatar
0/11 sssss1086
Where did you get the accordion boot? And how long and wide of one did you get? Im thinkin my cut out is gona be in the 40wide by like 14 or so tall.
Old 02-27-2013, 03:25 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
Not to stop you but if you have an ext cab there really isnt a need for blowthrough.
Unless u plan on adding more woofers.
Plus side is you can fit batts and amps in the bed now
92 Ranger Walkthrough
(Under Construction)
Old 02-27-2013, 03:27 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
i would cut out as much as you can, and that way you have room to go bigger int eh future. you can always build beauty panels to take up the extra space. and google accordion boot. most trucking websites have them
Old 02-27-2013, 03:31 PM
BASS14's Avatar
0/11 sssss1086
Yea i no i dont need a blowthrough but would be nice to.have a big system and not loose seat room and be uncomfy....
Old 02-27-2013, 03:35 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Well then youre on the right track lol.
Like don said. Cut as big as possible
0/11 ssss31258
stay 1/2" below the back window brace and 1/2" above the bottom of the bed.
This leaves you with about a 13" tall opening.
stay 1/2" away from each inside cab corner trim panel.
this leaves you with about a 34" wide opening.
mark your corners using a 3" circle.
this makes wrapping the boot easier.
using an air powered 'body saw' is the safest/easiest way to cut the metal. {no sparks}
Old 02-27-2013, 03:37 PM
Austin175's Avatar
0/11 sssss4224
Dang bro I was wondering when you was gonna get loud lol.....jk can't way to se the build.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 02-27-2013, 03:39 PM
BASS14's Avatar
0/11 sssss1086
Thanks! ^^^^^ planning on getting 4sheets of wood and some resin next week tuesday or wednesday and getting started on it. Goal is to have it playing by april 14th which is the first show in wi in madison
Sundown SA 6.5s in ford ranger Team Nemesis-Jared (Sundown Audio) 3 02-05-2013 10:05 PM
ford ranger kick panels projectred Wanting to Buy (WTB) 10 09-03-2012 07:48 PM
ford ranger HO alternator. 3g stang65 Wanting to Buy (WTB) 2 09-26-2011 03:16 PM
Ford Ranger new enclosure Riddla Member Rides & System Pictures 2 03-28-2011 10:19 PM
[SOLD] 1988 ford ranger fatpat1080 Miscellaneous Stuff For Sale 6 01-10-2009 06:39 PM
