4th order design sketchup - Car Audio Classifieds!
Old 03-02-2013, 11:27 AM
0/11 ssssss463
Default 4th order design sketchup
My 1st attempt at 4th design. Blowthrough in Silverado crew cab. Please check my math and let me know if you see any problems.
Old 03-02-2013, 12:00 PM
0/11 ssssss614
Good design should work well. If you can make ur sealed closer to 6cu and make ur port 12-14sq in of port per cube so if u do 6 cu and u keep ir port 10.5 high make it about 7.25 wide and tune it to roughly 45 and should pick up from 25 to 50hz easily.
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
02 s10 147.3 (louder now) on the dash
Old 03-02-2013, 12:01 PM
0/11 ssssss614
Btw wat power?
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
Old 03-02-2013, 12:02 PM
blazin20s's Avatar
0/11 ssssss334
Might have loading issues
2003 Mustang trunk build
2 loudforce 90 series 12s
8 audiopipe 1500s
3 group 31 batts
TEAM SOUND IMPRESSIONS
Old 03-02-2013, 12:07 PM
blazin20s's Avatar
0/11 ssssss334
And i agree with ^^^ make ur sealed chamber a little larger.....for music ur gonna want atleast a 2:1 ratio.....if ur using small power make it 3:1 the efficiency will make up for ur lack of power
8 audiopipe 1500s
3 group 31 batts
0/11 ssssss463
saz-1500 v.2 on the pair.
Old 03-02-2013, 12:12 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
what is fs of sa12 in 1.27 sealed. and that leaves you 3.3 sealed to 4 ported which isnt very good
Old 03-02-2013, 12:15 PM
0/11 ssssss614
Saz1500 and 2 sa 12s in a 3:1 would be brutal for any musical song
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
Old 03-02-2013, 12:17 PM
0/11 ssssss463
my math shows currently 1:1.78 ratio sealedorted based on net volume sealed after .14 displacement of sub. Port is 13sqin/vented foot(5x10.5=52.5sqin port area). With a saz-1500 this looks to be near perfect,
What do you mean by loading issues?
Old 03-02-2013, 12:20 PM
djscrubb's Avatar
0/11 sssss2332
dude read the 4th order thread i know its like 1000 pages but theres some basics in there ie a 1:1 ratio is not very good. and by loading he means the subs are firing towards each other. can you make it so the subs fire towards the port?
Need a 4th order design BlackWaterOp Enclosure Discussion & Design Construction Help 2 05-15-2012 10:06 PM
New 4th Order Design AFlem Enclosure Discussion & Design Construction Help 4 01-27-2012 04:29 AM
Which 4th order design? SPLEclipse Enclosure Discussion & Design Construction Help 6 05-24-2011 10:19 PM
First 4th order design AFlem Enclosure Discussion & Design Construction Help 20 04-29-2011 10:42 PM
4th order design 3rdshiftdiscretion Enclosure Discussion & Design Construction Help 20 01-25-2011 10:09 PM
