2 lvl 5 12s 4th or 6th need advice and opinions - Car Audio Classifieds!
Old 03-02-2013, 10:33 AM
Biggcaddi's Avatar
0/11 sssssss59
Default 2 lvl 5 12s 4th or 6th need advice and opinions
Hello everybody, im running 2 lvl 5 12s on a 10k and really want to get a new box that will let them shine to their full potential. I love the LOWS and want to keep the LOWS. I listen to rap, r&b, jazz, and pop. The current box is tuned to 28hz but its just a regular box. I been hearing alot about the 4th and 6th order boxes but would like to know which box is best for 2 lvl 5 12s and a 10k. Also i roughly have available space of 40w 36L 16h to work with, in a 99 escalade without 3rd row seating of course. Is it possible to do a 4th or 6th with the space available and would it be worth it to put the lvl 5 in one of those kind of boxes?
Old 03-04-2013, 02:33 AM
Brand New Members
0/11 ssssssss1
With overall measurement you gave...you only have 11.15 cuft. Only enough for a 2:1 ratio in a 4th order. But it would still get loud. I calculated 40Wx16Hx36D...back board to double baffle front would be 13.25" D, front board to front baffle board would be 22.75"D. Port inside dimension would be 6.75Wx14.5Hx11.735D (long). This would be 19-20sqin per cube. So 3cuft sealed with 6cuft port not including port displacement. You would do 2-45* corners on the back front port board corners, not on port side board, but at the corner. Make top or bottom board removable incase you need to get to the subs. Hope this helps...
The Following User Says Thank You to I'm not loud For This Useful Post:
Biggcaddi (03-06-2013)
Old 03-05-2013, 11:56 AM
GPCustoms's Avatar
0/11 ssssss661
What's the ebp?
Old 03-05-2013, 12:00 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
6th order. You should have more space than that in an Escalade too.
The Following User Says Thank You to jt_buck For This Useful Post:
Old 03-05-2013, 12:04 PM
GPCustoms's Avatar
0/11 ssssss661
Oh thats right DC doesn't list the tsp for the level 5s. Well if the level 5 is anything like the XL's, do not put those subs in a sealed box. The EBP of the XL 12" is 98.4
The Following User Says Thank You to GPCustoms For This Useful Post:
Old 03-06-2013, 07:24 PM
Biggcaddi's Avatar
0/11 sssssss59
My space is limited because i have my kinetic 3800s lined up against the back of the seats. I have tvs in the rear headrest and didn't want the box to high covering them up.
Old 03-06-2013, 07:30 PM
Biggcaddi's Avatar
0/11 sssssss59
Well GPCustoms you made a point that was bought up to me today and now i probably won't do this because of the sealed portion of the box. I hear it's not a good idea for the lvl 5 at all ! Thinking about maybe reconing to 15s or 18s in ported box. Thanks alot for the input.
Old 03-06-2013, 07:46 PM
0/11 sssss2649
In an escalade, I think you'd be much happier if you went with 15's in a regular ported box. I doubt you'll be louder by going bandpass in the space you have.
I'm running a 4th only because I have a very insulated trunk car with an arm rest that I can port through.
Old 03-06-2013, 07:47 PM
0/11 sssss2649
Nice to see more people from Fresno on here
Old 03-14-2013, 02:43 AM
ridintwo6s's Avatar
0/11 sssss1791
XLs work marvelous in 4ths .. OP do you have the m2 or m1 level 5?
some people seem to like the new level 5s in 4th too ...
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Tags
10k, 4th order box, 6th order box, dc audio, level 5 12
4th order opinions and need constructive advice:D KEVGNAR Enclosure Discussion & Design Construction Help 3 03-02-2013 02:06 AM
2 10s 6th order vs 2 12s 4th. Ringspun09 General Car Audio Discussion & Questions 1 02-28-2013 10:55 AM
4th or 6th Order? Question/Help/Advice/Tips/etc Please David97 Enclosure Discussion & Design Construction Help 7 11-04-2011 11:58 AM
need help/advice od a 4th or 6th order for 2 18's tahoefixssd Enclosure Discussion & Design Construction Help 1 09-12-2011 11:19 PM
Need some advice/opinions. silvercookie Sports and Fitness 10 04-08-2009 12:56 AM
