4th order wall or flat wall - Car Audio Classifieds!
Old 03-05-2013, 12:31 AM
Dirtbikerrob's Avatar
0/11 ssssss670
Default 4th order wall or flat wall
I currently have a 16 cube shell in my car. I plan on runnin 2 zv3s on 6k. Here's the thing. I'm debating on running 2 15s in a 2:1 fourth, or run 2 18s in a flat wall. What would perform better? If you were in my situation what would you choose
Old 03-05-2013, 11:55 AM
GPCustoms's Avatar
0/11 ssssss661
What vehicle?
I'd probably shoot for the 18s
Old 03-05-2013, 01:21 PM
0/11 ssssss670
97 escort. The last setup in it was 2 xl 15s on. 7k it did a 52.
I wanna shoot for a higher number and move more air
Old 03-05-2013, 01:33 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
2 18's flat wall.
Old 03-05-2013, 01:36 PM
0/11 ssssss670
See that's where Idk if I want to build them
As 18s because I have, 3 zv3 motors if I can pick up a fourth I would recone all the subs as 15s.
Old 03-05-2013, 01:38 PM
0/11 ssssss670
If I was to recone all 4 I would have to tear out the back of my wall to get more room.
Old 03-05-2013, 03:22 PM
GPCustoms's Avatar
0/11 ssssss661
do 4 15's in a flat wall on more power
Team Showtime Car Audio
Old 03-05-2013, 03:24 PM
team dc audio
0/11 sssss1268
Unless ur a rocket scientist or love to recone= do a flatt wall port on drivers side
Old 03-05-2013, 09:08 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
Check out these logs for some ideas:
DBescort Rebuild! - FloridaSPL
THE - FloridaSPL
I'm sure there are more, just ones that I've heard personally.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 03-05-2013, 09:25 PM
badmofo529's Avatar
0/11 sssss3329
4 12's 4th order
Sent from my Inspire 4G using Tapatalk 2
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Are 4th orders always louder than flat wall? Mnorwood01 General Car Audio Discussion & Questions 42 11-03-2012 12:46 PM
Flat wall 4th order, 8 DD 9515s Wildbillpb Build Logs 53 09-17-2012 04:36 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 08:37 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 03:01 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 06:50 PM
