One sa8v2 on 1k. Box ideas? - Car Audio Classifieds!
Old 03-05-2013, 11:44 AM
0/11 ssssss639
Default One sa8v2 on 1k. Box ideas?
I've done a few ported boxes and they sound alright, but I would like to do something more sq oriented. I know, 1k is a lot for sq. Being that I don't have a meter, my version of loud is probably different from a lot of people here. i really want to be able to enjoy my music, but crank it if i ever feel the need.
What is a good plan to go for with one 8" on 1k? I considered that 6th order from surreal but from what i read, overpowering the driver in that enclosure doesn't bode so well. Is this true?
Old 03-05-2013, 11:56 AM
0/11 sssss1480
Feedback Score: 63 reviews
I had a sa-8v2 powered by a clamped 1000 watts. I ended up with .45 net. It loss some on the low end but I wanted to ensure no mechanical damages.
Old 03-05-2013, 01:53 PM
0/11 sssssss18
I was wondering if you could curve a round port like that! I love the creativity. I'm kind of in the same boat as the OP. Would like to do a ported for sq but can't run deep ports. So sorry to the OP, no solutions for you but had to jump in a compliment the great box from JWS84.
Old 03-05-2013, 01:56 PM
0/11 sssss1480
Well it does decrease its efficiency and I had a little bit of port noise. But as you can see, I really didn't have any other options.
Thanks for the props
Old 03-05-2013, 09:08 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
I think 1000 watts to that sub might be a tad too much. I prob wouldn't go more than 800-900. I have the same sub.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
The Following User Says Thank You to Boomintahoe For This Useful Post:
gibsonm21 (03-06-2013)
Old 03-05-2013, 10:05 PM
0/11 ssssss639
Alright. I doubt the gain will be maxed anyway.
Old 03-05-2013, 10:34 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Why would you want to give that much power to the woofer? The gains are going to minimal especially playing music. If you want SQ, you definitely don't want a tiny box with a limited frequency response- and by that I mean a loss of low end. Essentially what you are creating is a SPL style box with a small air space and a huge port. That's all that box is going to be good on, the meter.
Old 03-06-2013, 01:05 AM
0/11 ssssss639
I'm a bit confused by that post, JT. You worded it as if i had already decided on a box. That's why this thread is here. I haven't yet. It's all ideas at this point. I've got the amp, a DD CM1000, but no woofer yet.
What would be a better option then? Something to dig deeper but still play loud if necessary.
Old 03-06-2013, 12:13 PM
0/11 ssss12531
Daily driving would be more ideal.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 03-06-2013, 01:37 PM
0/11 sssssss34
Are you limited to only a 8"?
box size for 2 sundown sa8v2 lotuskilla Enclosure Discussion & Design Construction Help 0 08-30-2012 07:22 PM
Box ideas xnewbx General Car Audio Discussion & Questions 10 06-26-2012 12:32 AM
sa8v2 box design 1loudmonte Enclosure Discussion & Design Construction Help 0 02-20-2012 06:25 PM
SA8v2 box 1loudmonte (Sundown Audio) 0 02-13-2012 02:39 PM
need your ideas for this box omgitscollin Enclosure Discussion & Design Construction Help 4 07-30-2010 06:46 AM
