2 sundows - Car Audio Classifieds!
Old 03-07-2013, 11:05 PM
0/11 ssssss318
Default 2 sundows
ok im sure the topic has been started a gazillion times. ive got 2 d4 sa12s and currently ive got them in 2 seperate boxes. one ~2.2 with a 12.5x2.5 38" long the other ~3.2 with a 6" aero 18" long. im getting some odd cancellation issues in the lowend and i believe its due to the 2 seperate port lengths having different time delays. im running them on a brz1700 at 1ohm. im thinking run them both inverted in the larger box common chamber and tune it around 30hz subs up port forward. how does this sound? ive found that LOWES sells 6"x24" green drainage pvc with a thinner wall damn near perfect for PSP aero flares. i plan to buy one of these. im doing a 143.3 at 36 right now w/ 1 window down and over a 142db @38hz sealed up. id like to get a 45 before i go to 15s. i plan to have my trunk glassed in down the road in the summer so this box is also just a temporary setup with foreseen changes in the future.
Old 03-07-2013, 11:37 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Uhhhhh why do you have them in tovdifferent size boxes?
Old 03-08-2013, 12:46 AM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
I'd start off with putting them in the same box, but..... I've been wrong before. Lol.
Old 03-08-2013, 10:58 AM
0/11 ssssss318
i had 2 boxes and wanted it in my car. im trying to avoid having to build a box. id much rather modify one of my current ones
Old 03-08-2013, 11:11 AM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
lol ITT pls dont do that man. just build urself a good enclosure and stop doing messups like this.
Old 03-08-2013, 11:12 AM
Fi_lexusIs's Avatar
0/11 ssssss281
using 2 boxes wouldn't be bad if they were the same size and same tuning but having 2 different sized boxes with different tunings is almost as bad as running 2 different woofers... save time fooling with the old and build a new box bro.
Old 03-08-2013, 11:51 AM
hotzie's Avatar
changin the game up
0/11 ssssss793
Actually I'd say this is a first time topic bout runnin subs in two diff sized boxes. U been long enough to know that u need to just buikd a simple littke box and put them in it and be done.build a 3.5 and use 6" bout 17 long and wang out
Old 03-08-2013, 11:54 AM
Mr.G6's Avatar
0/11 sssss4614
that has EPIC FAIL and 1000% wste of time and effort
just build a box for 2 of them thats PROPER and have at it
2000 Gmc Sonoma ext cab
Old 03-08-2013, 11:58 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
are you just wanting to do spl and burp at least a 145? if so you can do that with a single sa-12.
My game is legit,
Old 03-08-2013, 12:02 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You need a solid box design and build.
[SOLD] Sundows SAZ 3000d rodgabeatz Mono Amplifiers 26 05-09-2010 12:37 AM
