3 cubes, ported, 25-28hz, single 12" VVME RD-12 3/4" MDF - Car Audio Classifieds!
Old 03-08-2013, 05:11 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default 3 cubes, ported, 25-28hz, single 12" VVME RD-12 3/4" MDF
What would be a nice design for this sub in a 2010 HHR?
I don't need anything fancy. Was thinking just a sub up/port up design, 3 cubes tuned to 25-28 hz for the lows (all I play is decaf basically)
I have 39" w, 13" H, 27" L to work with.
Back of sub mount to end of magnet is a little under 6"
I also want to do a recessed mount or w/e but I'm sure I just need to glue and screw in a ring behind the baffle which won't be too hard at all?
Think 3 cubes is too much for the RD-12? It's suffering in the 1.75 32hz box. Maybe 2.5 or 2.75?
team graham
Old 03-08-2013, 05:17 PM
try a transmission line if you want low end reinforcement.
Old 03-08-2013, 05:26 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Will 39" be enough for the longest part?
team graham
Old 03-08-2013, 05:38 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
something like this maybe? then I would have room on top to stack stuff
team graham
Old 03-08-2013, 07:12 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Think I'm just gonna do a basic sub/port back ported box...this will be the first attempt so don't want to get too technical....
Any links to box calculators? I mean preferred ones if they are better than what I can find myself?
team graham
Old 03-08-2013, 07:18 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Ok got this.
How solid is this design? Seems super easy with only one piece for the port.
2.999 cubes, 25.8ish tuning
team graham
Old 03-08-2013, 08:39 PM
0/11 ssssss639
torres box calculator. Way better than the RE calc.
Old 03-08-2013, 08:49 PM
mega fatty
0/11 sssss6008
3cf seems on the large side for a single 12
What rd sub is it?
How much power?
I wouldn't tune lower than 32hz. Set your ssf for around 25-28 and let her rock!
Either way decaf doesn't go lower then 24hz iirc so you would be tuning to a frequency you would rarely play
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-08-2013, 09:16 PM
crav1n's Avatar
0/11 sssssss86
I wouldn't trust the RE calc..every time I've used it, it's been wrong
Colby Moorehead
Old 03-08-2013, 11:40 PM
Killer Audio's Avatar
0/11 ssssss604
Youre right on the box size. They need huge boxes to sound musical. Id do 3 cubes at 30 anything under is kind of pointless for that sub.
Sent from my DROID RAZR using Tapatalk 2
FS: Single 12" ported box DonH Wiring, Electrical & Other Installation Equipment 40 07-20-2011 01:23 AM
WTB: Single 8" Ported Subwoofer Box Jaredturp Wanting to Buy (WTB) 5 12-25-2010 05:05 PM
12'' sub for 2-2.5 cubes @ ~28hz on 2k Bobby32 General Car Audio Discussion & Questions 5 11-28-2010 02:26 PM
whats better for a single 15" - ported or sealed? n023b General Car Audio Discussion & Questions 4 10-30-2010 04:20 PM
12" single ported box. about 1.25 cf celicagtman Wanting to Buy (WTB) 10 03-14-2010 12:07 PM
