Round-over enclosure edges? - Car Audio Classifieds!
Old 03-09-2013, 01:34 AM
LowLyfe's Avatar
0/11 ssssss200
Default Round-over enclosure edges?
So I built an enclosure for my Grand Cherokee and i'm trying to achieve the look in the design below. The enclosure was made with 3/4" MDF and If I were to use a 3/4" round over bit would it work out this way or would it break off around the sub baffle where it's only 1/4" wide?
I'm new to routing and don't have any experience using roundovers But I realized I should have cut out a larger circle to get 2 seperate pieces on the flush mount baffle before attatching it but it's too late now.
Here's the said enclosure.
Here's the design I followed and what i'm hoping it to turn out like.
Old 03-09-2013, 01:48 AM
0/11 sssss2011
Feedback Score: 61 reviews
i'd personally use a 1/2" round over bit or even a 3/8" round over bit. just make sure you set the depth correctly.
Old 03-09-2013, 10:55 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Trial cuts on scrap wood....helpful hint, so you can see what it looks like before you make a final decision. Use mine all the time(roundover bits). Then, go over later with fine sandpaper.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 03-09-2013, 11:43 PM
NEVERDONE's Avatar
0/11 sssss2471
my guess would be yes it will break...its to thin to hold...
Old 03-14-2013, 02:37 AM
ridintwo6s's Avatar
0/11 sssss1791
take your time and use a smaller bit and set the depth correctly and youll be fine.
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Enclosure Build: 10" IAD Reign Demo Enclosure ;) Pioneer~Saturn Build Logs 57 11-18-2012 02:58 PM
rounding over edges JAYARE2007MAG General Car Audio Discussion & Questions 3 09-08-2011 11:12 PM
Round 3 Bushj311 General Car Audio Discussion & Questions 1 09-18-2009 03:12 PM
